#1044 - Access denied for user error when trying to import .sql
Thread begun 3/10/2018 2:51 pm by MRoc03795745 | Last modified 3/11/2018 10:09 am by Ray Borduin | 7055 views | 16 replies |
MRoc03795745
I have tried the tutorials for creating a database from two different articles. (using the example blue_sky_music.sql) One was importing the .sql file under the 'Import' tab and the other was for copying and pasting the .sql file into the 'SQL' tab and both times I receive this error. I checked with the host and the server is localhost. The user in the error message does not exist when I look it up under MYSQL Databases under cPanel. I tried googling the error and could not get any answers that way. When I check the databases the tables seem to have been created but I cannot connect with Dreamweaver CS6 no matter how hard I try. I followed the instructions for the article on how to connect Dreamweaver to a Database and cannot get anywhere that way either.
Here is the article tutorial I have been trying to follow. http://www.webassist.com/tutorials/Getting-started-with-MySQL-and-dynamic-websites
I spent $400 for DataAssist years ago and have never been able to use it.
Michael
Error
SQL query:
-- Create schema blue_sky_music
CREATE DATABASE IF NOT EXISTS blue_sky_music
MySQL said: Documentation
#1044 - Access denied for user 'cpses_in44ws7jyl'@'localhost' to database 'blue_sky_music'
Try deleting and manually creating the database table through php myAdmin. Most likely it is creating it with the wrong permissions somehow and by creating it manually you should be able to get around that.
MRoc03795745
Deleting and Creating Database Manually
I went to cPanel > Databases > MySQL Databases > and deleted the Database.
I do not know how to create this manually. Below is the .sql file that was listed in the article tutorial online. I'm exploring how to do this manually right now. Do you see anything wrong with the attached .sql file?
Michael
Go to cPanel > Databases > MySQL Databases and you should be able to click an Add Database button.
MRoc03795745
Create Database
Yes, I went there and created a new database, a new user, then applied the new user to the new database with all of the privileges.
I tried from the unsuccessful import of sql that generated the 1044 error Select All > Copy > and copy to new database but that did not work so I exported the table from the 1044 error sql that I imported and imported it to the new database that I created and it imported successfully with no errors.
So are you up and running? Where are you with this now? Still need my help? If you are still getting errors, let me know the exact error you see. I don't see any issues with the .sql file.
MRoc03795745
Right now I am going to try to connect Dreamweaver to the database. I received problems there as well. I am following the instructions on http://www.webassist.com/community/tutorials/view_tutorial.php?tid=92 and have entered the connections settings as attached.
MRoc03795745
Now I am following the instructions on http://www.webassist.com/community/tutorials/view_tutorial.php?tid=94 connecting the database to dreamweaver.
Dreamweaver > Window > Databases > + > MySql Connection
Connection Name: dataassist
MySql Server: localhost
User Name: internet_user
Password: ***password for internet user***
Database: internet_test
Then I get the error, "An unidentified error has occured."
MRoc03795745
Just tried it again by creating a new site in dreamweaver and got the same error but attached is a screenshot with an error with more info.
MRoc03795745
Here are screenshot of what was entered into Dreamweaver.
