Error after upgrading to PHP 5.6 MySQLi
Thread begun 3/09/2018 3:51 pm by cldsk | Last modified 3/10/2018 6:31 pm by Ray Borduin | 4149 views | 9 replies |
cldsk
MySQLi Error after upgrading to PHP 5.6
Hello, after having trouble with a gallery module I am using, I discovered the client's GoDaddy Server was running PHP5.2, so I had to upgrade it to 5.6 (that was the highest option). On doing this, I am now getting the following error on the admin_cms/ page:
Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/content/48/8996548/html/Connections/PowerCMSConnection.php on line 11
Warning: Cannot modify header information - headers already sent by (output started at /home/content/48/8996548/html/Connections/PowerCMSConnection.php:11) in /home/content/48/8996548/html/webassist/security_assist/helper_php.php on line 65
When I created the connection I used the standard MySQL as I was under the impression that MySQLi was not supported yet in PowerCMS? Is there a way to change the connection type? Do I have to redo everything I already have done in the database? I do have the latest MySQLi Server Behaviors installed in Dreamweaver.
Thanks for any advice/help.
That is a deprecated warning and not an actual error. You should be able to turn that off without effecting the functionality of the page. You can either turn it off in the php.ini from your hosting control panel, or turn it off on any individual pages where you see the problem.
error_reporting(E_ALL ^ E_DEPRECATED);
cldsk
thanks so much, just to confirm, at this point we cannot use MySQLi with PowerCMS though, correct?
cldsk
I tried adding in that to the php.ini file, after clearing cache it still doesn't work.
Here is the php.ini contents:
register_globals = off
allow_url_fopen = off
expose_php = Off
max_input_time = 60
variables_order = "EGPCS"
extension_dir = ./
upload_tmp_dir = /tmp
precision = 12
SMTP = relay-hosting.secureserver.net
url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=,fieldset="
; Only uncomment zend optimizer lines if your application requires Zend Optimizer support
;[Zend]
;zend_optimizer.optimization_level=15
;zend_extension_manager.optimizer=/usr/local/Zend/lib/Optimizer-3.3.3
;zend_extension_manager.optimizer_ts=/usr/local/Zend/lib/Optimizer_TS-3.3.3
;zend_extension=/usr/local/Zend/lib/Optimizer-3.3.3/ZendExtensionManager.so
;zend_extension_ts=/usr/local/Zend/lib/Optimizer_TS-3.3.3/ZendExtensionManager_TS.so
; -- Be very careful to not to disable a function which might be needed!
; -- Uncomment the following lines to increase the security of your PHP site.
;disable_functions = "highlight_file,ini_alter,ini_restore,openlog,passthru,
; phpinfo, exec, system, dl, fsockopen, set_time_limit,
; popen, proc_open, proc_nice,shell_exec,show_source,symlink"
Not sure what might be in conflict?
This is a line of php code for a .php page:
the same line in the php.ini file would look like:
error_reporting = E_ALL ^ E_DEPRECATED
cldsk
Thanks for the quick reply. I have tried with that as well, but the error still shows:
expose_php = Off
max_input_time = 60
extension_dir = ./
precision = 12
;[Zend]
Does adding this work:
display_errors = Off
Maybe it isn't using that php.ini file.
cldsk
That didn't work either :(
It is the only php.in file in the server (I did a server search with FileZilla, and that is the only one that came up).
Following instructions at: https://www.godaddy.com/help/change-php-settings-26379
I also tried creating a php5.ini file and using this: error_reporting = E_ALL & ~E_DEPRECATED & ~E_NOTICE
as seen in:
https://www.godaddy.com/garage/suppressing-warning-messages-php-deprecated-functions/
But that didn't work either
Just to confirm, there currently isn't MySQLi support for PowerCMS with the MySQLi Server Behaviors extensions that I could switch the connection type, correct?
That is correct. PowerCMS does not currently work with MySQLi.
You may want to contact godaddy about this. It appears to be ignoring your php.ini file and they should be able to tell you the proper way to disable deprecated messages.
cldsk
Thx again for the reply. Finally figured it out - for this client's hosting package it reads a php56.ini file instead of a php.ini file. Once I created that, and used the code you gave me it worked and it came back up.
Thanks again for your help - sorry to have bothered you with this!
