Can't find MySQLI recordset or Data Management after reinstalling Webassist
Thread begun 3/07/2018 7:57 pm by madahmani | Last modified 3/10/2018 6:32 pm by Ray Borduin | 3287 views | 8 replies |
madahmani
My question seems confusing but I will try to explain better.
I had Dreamweaver with DataBridge and MySQLI installed on an old computer and I created a website for my client on it in 2017.
This year, the customer wanted to make updates to his website. I installed Dreamweaver with DataBridge and MySQLI on a new computer.
The installation was smooth and everything went fine with no errors (I had a long time experience with WA :) )
My problem started when I wanted to update the MySQLI Insert and Update Data management Records from the Server Behaviors Panel.
I didn't find them! And there was no recordsets at all! All I found is a long list of Dynamic Text Fields as you can see on the attached file.
The code on the page is all good and has all the Insert, Update and File Management functions but I can not update them as I can not see them listed on the Server Behaviors Panel.
Please help me. Thank you.
It looks like the form fields aren't using standard quotes. They are using angled quotes. You may be able to update that in the HTML code. That is the only thing I can think of that would cause that looking at the page.
madahmani
I have checked and I think they are standard quotes. Please see the attached image and tell me if I am wrong.
Please attach the page you are working on. If you go to add a MySQLi Server Behavior from the server behaviors panel does it show up there?
madahmani
Please find the page attached and sorry but I didn't understand this part: " If you go to add a MySQLi Server Behavior from the server behaviors panel " do you mean like adding a MySQLi Insert record for example?
Thank you.
If you go to the Server Behaviors window and click the "+" button. Do you see an option to add WebAssist->MySQLi->MySQLi Recordset?
I was able to open your file and I see the server behaviors. I had to replace some extra line breaks in the file, that might be your issue. You see how every other line has an extra line break? That shouldn't happen and would prevent the server behaviors from reading the code properly.
I've attached a version with the line breaks removed for you to test with.
madahmani
Thank you Ray, Yes I do see this: WebAssist->MySQLi->MySQLi Recordset
I think you forgot to attach the file.
The attached file should be there now.
madahmani
Ray, thank you very much for your assistance. I highly appreciate it.
After a close inspection, I found the cause behind this.
Because I moved my WA and Dreamweaver installation to a new computer, I downloaded the website php source files from the FTP using Filezilla and somehow, when copying the files, it changed them that way. I have seen Filezilla do weird things when copying depending on the copy mode used.
I downloaded again the source files using WinSCP and everything was clean and correct.
