Validating image size before uploading
Thread begun 3/05/2018 9:46 am by iain331081 | Last modified 3/14/2018 3:49 pm by anonymous | 5238 views | 15 replies |
iain331081
This is one I had some help about ages ago, and had a page checking the the width of an image fell between two values. I now have a requirement to check the image is an exact size, so need it to check the height and the width.
I have attached a page with what I thought it should be, but doesn't seem to be.
Can you have a quick look and let me know what I have wrong? I think it must be something along these lines.
Thanks.
You need to move the file upload code above the validation code in order to validate the dimensions. Then you would also have to use the bindings from the file upload for the width and the height and not the values from the $_FILES array.
iain331081
Thanks Ray,
It should be something like:
$WAFV_Errors .= WAValidateNM($WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_1"]["imageWidth"] . "",299,301,"",",.",true,1);
$WAFV_Errors .= WAValidateNM($WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_1"]["imageHeight"] . "",199,201,"",",.",true,3);
iain331081
Thanks Ray - I think you might have used a slightly different method when I asked about this originally.
Yes. If you add code like that above it will allow you to validate the size without moving the upload code above. This is actually a better technique since you wouldn't have already uploaded the file before validation and wouldn't need to clean up old files that didn't meet the validation requirement.
iain331081
Can you see where I've gone wrong with the validation on the height? Its failing the validation even with a 300x200 image.
Please attach the latest version of the file you are working on. I'll take a look.
iain331081
Thanks Ray.
You have:
$image_info = getimagesize($_FILES["news_image_small"]["tmp_name"]);
$_FILES["news_image_small"]["height"] = $image_info3[0];
it should be:
$image_info3 = getimagesize($_FILES["news_image_small"]["tmp_name"]);
