File upload validation
Thread begun 3/02/2018 2:16 pm by danielsebas | Last modified 3/02/2018 4:04 pm by Ray Borduin | 2265 views | 3 replies |
danielsebas
Hi Ray I want to restrict a file upload to PDF and to certain size and send it by email with:
Server validation
JQuery validation
File upload
Create Email Message
How can I do it with those behaviors?
Thank you.
Regards,
Daniel
File upload can upload the file... Then server validation can be used to validate the size and extension before the email is sent. JQ validation happens in the browser before the form submits.
danielsebas
Thank you Ray, I'll try with server validation. For the file extension server validation which of the file field binding options should I select when I press the lightning?
It depends on the type of validation you are using. I think there is a fileExtension validation type and you can just use the server file name to validate. The server variable should be coming from the file upload binding not the form directly. Also make sure you move the file upload code above the validation. It will be below by default and will need to be moved above to validate file size.
