Warning: Missing argument 14 for eCart1_Definition::AddToCart(),
Thread begun 3/01/2018 3:56 pm by MAURIANS | Last modified 3/02/2018 2:52 pm by Ray Borduin | 1868 views | 4 replies |
MAURIANS
When "ADD TO CART" button is pressed adds items to cart but displays error below and will not redirect to page.
here is site: www.modestroyals.org all things are tested on site
Warning: Missing argument 14 for eCart1_Definition::AddToCart(), called in "products_detail.php" on line 130 and defined in "WA_eCart/eCart1_PHP.php" on line 27
Warning: Cannot modify header information - headers already sent by (output started at WA_eCart/eCart1_PHP.php:27) in "products_detail.php" on line 147
This usually means you have added a column to your cart but haven't updated your add to cart server behavior to include a value for that new column.
MAURIANS
The Cart adds items but will not redirect when button is clicked. but on LOCALHOST it works without any problem...
You probably have a space or blank line in your php code above your redirect. That will prevent it from changing pages on some php versions.
MAURIANS
Thanks I looked at the coding made sure no "blank spaces" was made.
I updated ADD TO BUTTON on detail pages working smoothly....
