Dropdown Selection set up not seeing recordsets?
Thread begun 3/01/2018 2:42 am by mikec156913 | Last modified 3/07/2018 9:21 am by Ray Borduin | 5074 views | 13 replies |
mikec156913
The Dynamic List/Menu is not showing defined recordsets. There are 3 record sets defined on this page.
This issue has only happened since I purchased and installed eCart last evening. Until eCart installation this issue was not showing. Tried new install of DW CC 2018, reinstalled DataBridge, MySQLi and eCart. Removed the MacFileCache data file. Tried New installation of DW with other extensions but without eCart and all worked fine again. Extensions installed with DMX Zone Extension Manager.
DW CC 2018, MAC Pro, OSX 10.10.5, PHP 5.6, MySql 5.7
Any help gratefully received.
Mike.
Try uninstalling and reinstalling just DataBridge. Perhaps an older version of the file in eCart is causing issues.
mikec156913
Databridge issue uninstalling
Hi Ray,
Databridge will not uninstall correctly - see image attached. After clicking OK on these messages, Dreamweaver sits doing nothing and I have to Force Quit.
I did restart DW, stopped and reinstalled Databridge, restarted and entered serial number but same issue as previous message on the selectbox.
Regards,
Mike.
What version of Databridge are you trying to uninstall? I'll try to reproduce it and get it fixed.
You can always rename your Dreamweaver User configuration folder to effectively uninstall all of your extensions at once. I'm not sure how many extensions you have installed so that may or may not be a viable option.
mikec156913
Databridge v1.2.4 MySQLi v1.0.5 eCart v6.1.2
I have sine done another clean install of DW CC 2018 after manually removing all extensions from the DMX Zone manager. I then installed eCart first followed by MySQLi and then Databridge. I regret that the same issue still occurs in binding a recordset in the selectionbox, it shows None. Not sure if this information may be of help or not.
Mike.
Are recordsets listed in your server behaviors window? Can I get FTP access and a URL to your website to reproduce the issue?
mikec156913
PM you Ray.
If you give me FTP access and the url to the live site I can try to reproduce the problem. If I can reproduce it then I can fix it.
mikec156913
Pm
I see you are using MySQLi recordsets. Try installing MySQLi Server Behaviors after eCart and I think this issue won't happen.
