error keeps telling me to check for internet connectopms
Thread begun 2/27/2018 12:13 pm by i.edwards384429 | Last modified 2/28/2018 9:10 am by Ray Borduin | 1746 views | 2 replies |
i.edwards384429
error keeps telling me to check for internet connections when opening file in dreamweaver
Hi
I downloaded the Databridge extension and then installed it using extension manager cc.
When I start up dreamweaver and open a page I get a message box showing three stages
step one downloading files ( green)
after several minutes i'm told "Error could not connect to Web Assist server make sure you are connected to the internet and try again"
I am connected.
At this point dreamweaver stops responding.
Any ideas?
thanks
Ian
I can walk you through manual installation. It tries to download and unzip a file, so we can do that manually. What is your username on your computer? Sometimes special characters can cause issues when it downloads. If you give me a phone number to reach you I can give you a call and help you with a manual install.
i.edwards384429
Hi Ray
the problem resolved it's self in that when Dreamweaver and the webassist were not responding I left them and after two hours the PC was still locked out. So I went to bed and when I got up it had all cleared its'self and worked.
it seems as if the extension was using the option to install despite the fact that before strting Dreamweaver I downloaded and saved the extension and then did a manual install using extension manager cc.
Any problem solved
thanks
Ian
