some orders not going into the database
Thread begun 2/27/2018 7:23 am by Jamie | Last modified 3/19/2018 7:14 pm by Ray Borduin | 3828 views | 7 replies |
Jamie
Hey Ray
On an existing ecart installation, strangely an occasional order will be added but the summary is not added to the database (the details are).
I really dont know how to troubleshoot this one as I have no idea why most are fine yet there is the occasional error....
all help gratefully received
Have added info to the PM
Unfortunately I can't spot any issues that would cause this. We would have to first reproduce it. Without being able to reproduce it, we wouldn't be able to test if it was fixed if we did make changes.
Try maybe a second order without logging out? Using a phone? I'm afraid I wouldn't know were to start without reproducing it.
Jamie
thanks Ray. I just cant replicate it... any suggestions on a methodological approach to testing the possible causes to try and replicate it?
If it is inserting in wrong and not updating it wrong later, you could probably prevent it without reproducing it.
It isn't the way I like to do things, because the underlying problem remains, but without reproducing it that might be your best option.
On line 29-30 of confirm.php you have:
if (isset($_POST["Payment_submit"]) || isset($_POST["Payment_submit_x"])) // Trigger
That is the trigger that does the insert summary. Below that you could add another final check:
<?php require_once("webassist/form_validations/wavt_scripts_php.php"); ?>
if (isset($_POST["Payment_submit"]) || isset($_POST["Payment_submit_x"]))  {
$WAFV_Redirect = "checkout.php";
$_SESSION['WAVT_payment_Errors'] = "";
   if (
$WAFV_Redirect == "")  {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ(WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','First_Name') . "",true,1);
   if (
$WAFV_Errors != "")  {
PostResult($WAFV_Redirect,$WAFV_Errors,"payment");
That way if it ever gets to that point without a First Name value being set, it will redirect to the checkout page and start the checkout process over. It should prevent the problem even without understanding it. Then if you ever find a case where you can't checkout and it keeps starting over you have reproduced the problem.
Jamie
ok thanks, so does that block of code go on line 88 (between store summary and store details)?
So I am assuming that we need to keep an eye out for a customer that says they keep getting thrown back to the start of the checkout process and we need to find out from them what/how they are doing to try and then replicate the issue?
It should go above the store summary... so above both. And yes look out for a customer or in your testing if it ever gets stuck going back to the checkout page you have reproduced it.
Jamie
ok, many thanks Ray
Jamie
This post has been deleted.
