searching with data assist where field contains text not exact match
Thread begun 2/22/2018 6:24 am by gb261593 | Last modified 2/23/2018 10:03 am by Ray Borduin | 3108 views | 6 replies |
gb261593
I have a Data Assist 2 and have used it to develop a query where it searches through 3 fields - forename, surname and firm. It works fine if the exact name is entered but I want it to find data which is partially entered eg finds Timothy and Tim etc if Tim is entered in the forename entry.
Is this possible and if so, how do I do it.
Yes. You can do an "includes" or "begins with" search instead of an exact match. If you attach the results page, I could show you the code that needs to be updated.
gb261593
Thank you. I attach the results page - not tidied up but working OK.
on lines 19-21 you have:
$WADbSearch1->addComparisonFromEdit("surname","surname","AND","=",0);
$WADbSearch1->addComparisonFromEdit("forename","forename","AND","=",0);
$WADbSearch1->addComparisonFromEdit("contacts.clientid","clientid","AND","=",0);
you can update it to:
$WADbSearch1->addComparisonFromEdit("surname","surname","AND","Begins With",0);
$WADbSearch1->addComparisonFromEdit("forename","forename","AND","Begins With",0);
gb261593
Thank you. This works fine putting in the first part of the name. Is it possible to have it look for results that contain the entered text? For example, if I put in 'liam' in the surname field I would like it to be able to find Wiliams, Wiliamson, etc.
Use "Includes" instead of "Begins With"
gb261593
Excellent. Thank you very much - that works perfectly.
