plugin and updating
Thread begun 2/21/2018 7:36 am by Jamie | Last modified 2/23/2018 1:04 pm by Ray Borduin | 4319 views | 8 replies |
Jamie
plugin and updating
Hey Ray
I need to give a client the ability to create colour sets for an ecommerce installation.
Have the colour set pages colorsets_insert, _update and _results (colour_sets, ColourSetID, ColourSetName)
When you go into colorsets_update for the relevant ste, I have plugged in colors_results.php (colours, ColourID, ColourName, ColourImage and SetID) and need to filter these results by SetID which should match ColourSetID from the parent page. Then when you click on insert or update, it needs to use the SetID to insert or update into the database. The redirects and 'cancel' need to go back to the relevant colorsets_update.php page associated with that ID.
Have attached the relevant files.
Jamie
I'm going to have to work with you directly on this. I'll need to see it in a browser to understand what is going on and debug what needs to be fixed.
Jamie
ok, have manged to get this working in the main.
the only aspect I cant get to work is the redirect when deleting an entry on the plugged in page (colors_results.php)
Have set it to
$WA_redirectURL = "colorsets_update.php?ColourSetID=".($_SESSION['ColourInfo'])  ."";
however when you try to delete an entry, it redirects to
and am unsure why it isnt incorporated in the ColourSetID
Have attached both the parent page (coloursets_update.php) and the plugged in page (colors_results.php)
Jamie
Are you sure this is the uploaded page? It looks like it should work. I'd have to debug to see what is going on.
Jamie
its definitley up. See PM
When I download that page from your live site I see:
$WA_redirectURL = "colorsets_results.php";
That page is colorsets_update.php
Jamie
But the delete is on colors_results.php
OK to be honest I don't quite know what was going on, but I was able to fix it by removing the form action from the forms on the page. That causes the action to use the current page and included the url parameters. The issue wasn't with the redirect, it was the form action that was removing the url parameters before the delete took place.
Jamie
gotcha many thanks Ray
