Querry runs fine on local but not on remote without error - it returns just blank page
Thread begun 2/10/2018 1:45 am by kost36 | Last modified 2/12/2018 10:52 am by Ray Borduin | 2132 views | 4 replies |
kost36
<?php require_once('Connections/local_mysqli.php'); ?>
<?php require_once('webassist/mysqli/rsobj.php'); ?>
$Recordset3 = new WA_MySQLi_RS("Recordset3",$local_mysqli,0);
$Recordset3->setQuery("SELECT eak_nominees.`Title`, eak_nominees.`Director` FROM eak_nominees WHERE eak_nominees.katigoria_nominee LIKE 'Documentary%' ORDER BY eak_nominees.`Title` ASC");
$Recordset3->execute();
<!doctype html>
<html>
<head>
<meta charset="utf-8">
</head>
<body>
while(!$Recordset3->atEnd()) {
<table>
<tbody>
<tr>
<td><?php echo($Recordset3->getColumnVal("Title")); ?> (<?php echo($Recordset3->getColumnVal("Director")); ?>)</td>
</tr>
</tbody>
</table>
$Recordset3->moveNext();
$Recordset3->moveFirst(); //return RS to first record
</body>
</html>
thank's
/kostas
A blank page usually means you haven't uploaded the include files necessary. If you add this to the top it may show the error instead of a blank page:
ini_set('display_errors',1);
kost36
it returns
Warning: mysqli_stmt_result_metadata() expects parameter 1 to be mysqli_stmt, boolean given in /home7/kost36/public_html/webassist/mysqli/rsobj.php on line 478
Warning: mysqli_num_fields() expects parameter 1 to be mysqli_result, null given in /home7/kost36/public_html/webassist/mysqli/rsobj.php on line 480
Warning: mysqli_fetch_fields() expects parameter 1 to be mysqli_result, null given in /home7/kost36/public_html/webassist/mysqli/rsobj.php on line 481
Warning: mysqli_free_result() expects parameter 1 to be mysqli_result, null given in /home7/kost36/public_html/webassist/mysqli/rsobj.php on line 483
Warning: mysqli_stmt_store_result() expects parameter 1 to be mysqli_stmt, boolean given in /home7/kost36/public_html/webassist/mysqli/rsobj.php(472) : eval()'d code on line 1
Warning: mysqli_stmt_bind_result() expects at least 2 parameters, 1 given in /home7/kost36/public_html/webassist/mysqli/rsobj.php(472) : eval()'d code on line 1
It looks like your database connection information is wrong for the live server. Open the connection file and make sure the server name, username, password, and database name are correct.
kost36
thank's Ray, solved
