How to set upload folder
Thread begun 2/09/2018 8:34 pm by DeanCollins | Last modified 2/12/2018 10:52 am by Ray Borduin | 1584 views | 4 replies |
DeanCollins
Hello! Thanks for your help with my previous question about the HTML Editor. I have another.
I've set my upload folder as "..docs/news/images." And here's the code in the page:
$CKEditor_config["filebrowserBrowseUrl"] = "../webassist/kfm/index.php?uicolor=".urlencode(isset($CKEditor_config["uiColor"])?str_replace("#","#",$CKEditor_config["uiColor"]):"#eee")."&theme=webassist_v2&startup_folder=../docs/news/images";
However, uploads don't make it to that folder. Instead they wind up in "../img/uploads." And, if I upload a document such as a PDF, they get uploaded to "../img."
I must be missing a setting somewhere. Or I'm not seeing it. How do I get the uploads to go to the correct directory?
That is set up in the webassist/kfm/configuration.php file. If you send me a copy of that file I can help you with line numbers and code.
DeanCollins
It's attached.
line 9:
$WAGLOBAL_images_folder = "img/uploads";
just set that to:
$WAGLOBAL_images_folder = "docs/news/";
DeanCollins
Thanks!
