input type TIME field not displaying
Thread begun 2/08/2018 4:28 am by eric284736 | Last modified 2/08/2018 11:44 am by Ray Borduin | 2233 views | 4 replies |
eric284736
Hi Ray,
I have an update page that has a couple of TIME fields and one works while the other does not. The one that works displays the time correctly as 5:30 PM and the other one will not display, it just shows the time pattern.
Correctly displayed:
<div class="lineGroup"> <label for="arrvtime" class="sublabel" > Arrv Time:</label>
<input id="arrvtime" name="arrvtime" type="time" value="<?php echo $row_WADARegistrationTable['arrvtime']; ?>" class="formTextfield_Medium" tabindex="42" title="Please enter a value.">
Not displaying
<div class="lineGroup"> <label for="departtime" class="sublabel" > Depart Time:</label>
<input id="departtime" name="departtime" type="time" value=" <?php echo $row_WADARegistrationTable['departtime']; ?>" class="formTextfield_Medium" tabindex="49" title="Please enter a value.">
Both are TIME datatypes. Not sure what I am missing.
thx
Eric
Is the value correct in the database? Is it a display problem or a save problem? I can't spot a problem on the page.
eric284736
Yes, the database entry is 18:07:00 which should display as 6:07 PM. I could not find anything wrong on the page either. It is really weird.
Change the input type from "time" to "text" and see what displays. I see you have a space in front of the value. See if that is causing issues.
eric284736
Thanks Ray!! I removed the space and that did not seem to be the issue. Changes the type to text and then back to time and it worked.
Thanks!
