How do i correct this issue in dw6
Thread begun 2/05/2018 8:05 am by software.current355386 | Last modified 2/07/2018 9:03 am by Ray Borduin | 2021 views | 3 replies |
in the dw interface the section that show all the moudels is pointing to wrong file hen i hover over it
source is in site MYTB but itsayig ing that if pointing two another defined site LDIIT the file is correct otherwise, is this likely to cause problems if so how do i core act
nb MYTB is accesd b y most of m y sites accessing via f all url and contains css coding primay
Can you send a screen shot? I'm not sure I understand the problem.
see pm
This won't be a problem on your live site and can be ignored. Is it possible that you have a defined site in dreamweaver pointing to that url and that is why it tries to find it in the associated directory? Ultimately this won't be an issue, so I'd just ignore it.
