php7 msyqli insert id
Thread begun 2/01/2018 12:40 pm by localidiot | Last modified 2/19/2018 9:23 am by Ray Borduin | 881 views | 2 replies |
localidiot
When i insert a new record using mysqli i like the option to set the newly created ID with a session ID.
Since going to php7, I am having an issue with this session variable.
i realize the limited support for mysqli suite and php 7. I am just trying to get it running in a php7 environment and will tweak it as needed.
I appreciate your help.
It should work just fine. I'd need FTP access and steps to reproduce in order to debug an issue like this.
localidiot
Ray thank you for your support. The level of support you give continually throughout the lifecycle of these products is exhausting.
My issue turned out to be something odd with the database import export, as on my new server I went in and set a default value for a column i wasnt setting a value on.
not sure why or how this creeped up but its working now.
