Adding Google reCaptcha to Data bridge page
Thread begun 2/01/2018 7:47 am by iain331081 | Last modified 2/07/2018 7:50 pm by Ray Borduin | 4597 views | 8 replies |
iain331081
I am just looking at adding the Google reCaptcha to a WA based page. But I'm not sure about the position of where to put the various bits of PHP for doing the insert and sending email notifications as well when the form is submitted.
I have attached a page that had the reCaptcha working - but in its current state it displays success or fail messages correctly, but at the top of the page. Ideally they would be down the page at line 370 next to the reCaptcha graphic.
And it needs to do the insert and trigger the emails if the reCaptcha validates. I think its hopefully just a case of moving a couple of bits around, or putting some of the WA code inside the 'else' part of the reCaptcha code at the top. I've had a go, but couldn't seem to get it.
Thanks for having a look.
iain331081
OK - think I've made a bit of progress. I have put the insert and email code inside the ELSE statement for the reCaptcha.
I have it working now so that it shows the the fail message at the top of the page if the reCaptcha isn't validated. Can you have a look at check its done as it should be? I know sometimes things might work, but might not be done as they should.
And when it is validated it is inserting the new record, and triggering the two emails correctly.
The only thing I'm not sure is how to have the error message appear down at line 384?
Also, can you remind me of how to keep the form contents in the input boxed persist if the reCaptcha fails, so that people don't have to fill in the form again?
iain331081
I have another variation, with all of the relevant code moved down to the <div> where the captcha fail message should appear.
This one displays the message in the correct place, inserts the record, and triggers the two emails.
But isn't redirecting to the thanks page....
So I have two that are nearly there but not quite....
The code is in the wrong spot.
1) Move all of the code above the: <!doctype html>
2) replace this code:
if(intval($responseKeys["success"]) !== 1) {
echo '<br><h5>Please check the captcha</h5>';
} else {
with this:
if(intval($responseKeys["success"]) === 1) {
Then use this in the div where you want the message to appear:
if(isset($_POST["Registration_submit"])){
                            echo
iain331081
Thanks Ray. That has sorted the reCaptcha, but its submitting without the required fields being entered.
It doesn't look like there is any validation on those fields. Open the WA Server Validations server behavior from the server behaviors window and you should be able to add the other validations back in.
iain331081
Thanks Ray - my serial number is being rejected on my laptop as its had two activations already. I've changed computers over time, but do only have my desktop and laptop now.
You can click the "Clear Activations" button on the "All My Downloads" page linked from your account to activate on a new computer.
iain331081
Ah, OK - thanks Ray. I got it working with the jquery / Bloom validation, rather than the server validations.
I'm away now so can't double check, but I'm sure it was working on my desktop, but wasn't on my laptop. But the code in the PM below was missing. I added that and it worked again, with the Bloom styling and positioning. (It had been working without it I'm sure, just with the default position and style of the validation message.)
Not sure why, but don't suppose it matters now that it seems OK.
