Site breaks with update to PHP 5.6
Thread began 1/31/2018 11:51 am by BillHobbs | Last modified 1/31/2018 4:31 pm by Ray Borduin | 1078 views | 3 replies |
BillHobbs
Here is the error message I get. Godaddy said it was in the way the site is connecting to the database. I've added the connection script.
Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/content/01/9510801/html/BlackFitAndSingle/Connections/connSiteDB.php on line 9
Deprecated: mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/content/01/9510801/html/BlackFitAndSingle/Connections/connSiteDB.php on line 14
connSiteDB.php
That is just a warning. You can turn warnings off and it won't effect the functionality. It is just warning you that your code won't work on php7, but it won't actually cause issues in 5 or even 6.
BillHobbs
How do I turn the warning off?
error_reporting = E_ALL & ~E_DEPRECATED & ~E_NOTICE
Or you may add the following line to a PHP file itself, inside existing or new <?php ?> tags:
error_reporting(E_ALL & ~E_DEPRECATED & ~E_NOTICE);
You can contact godaddy support if you need help finding your php.ini file to update it.
