Never receive mail using PEAR
Thread begun 1/30/2018 10:29 am by vernon webb | Last modified 1/31/2018 11:44 am by Ray Borduin | 4567 views | 15 replies |
vernon webb
I am moving to a new server which requires my sending email using authentication so I am using the Universal Email with PEAR Mail with SMTP. All seems to work well but I get no email. I have no idea how to trouble if all seems to go well with no errors. Would appreciate any help.
I'd suggest trying the DataBridge Alpha build.
The email code has been updated so that PEAR is no longer needed for authenticated email:
http://www.webassist.com/forums/posts.php?id=40733
vernon webb
Installed and trying but got an error in this line, which I don't see the error:
$Email->Subject = "\".$row_rsCLIENT['repName'] .\" Is Due a Commission Check";
vernon webb
Above and beyond that the page is now experiencing a 500 error.
That line should read:
$Email->Subject = "".$row_rsCLIENT['repName'] ." Is Due a Commission Check";
Can I get FTP access and a URL to debug the 500 error? Did you upload the webassist/ecart folder?
vernon webb
OK
I found a few issues that I corrected and the page is trying to send the email now.
One issue is that you explicitly have the page set to not send if the repid is 1, and that is the rep for this account.
I added:
|| 1==1
to line 71 to allow it to send when the rep is 1.
I've added debug code to the page that you will see.
Try updating line 83 and 84 to use the correct username and password. Once the email is sending properly you can delete line 79 to remove the debug code and delete line 99 to let the code finish processing and redirect.
Let me know if your email still doesn't send after updating the credentials. Also make sure the smtp server host name is correct on line 81.
vernon webb
The server behavior is now gone. I have no idea where to check the password.
vernon webb
Actually when I look at the lines of data for that the host is gone and all the information is in the wrong place, for instance the password is the host address...
Yes. I moved them around because some seemed wrong in the code. That is why I mentioned they should be checked and reset.
