Example "Before Page Load" and/or "on form submit" trigger for Classic ASP - to solve UE issue.
Thread begun 1/29/2018 11:29 am by Nathon Jones Web Design | Last modified 1/29/2018 3:52 pm by Ray Borduin | 1996 views | 5 replies |
I'm currently using the "when button is clicked" as the trigger for UE:
if (cStr(Request.Form("SubmitEnquiry")) <> "")  then
...but I just realised that the form's button is on the previous page so this is useless! D'oh!
Thing is, DWCC won't let me open WebAssist wizards for ASP. Can anyone help me with the code for those two triggers so I can test them both?
Thank you.
NJ
It would work if the form button was on the previous page as long as the page action points to the new page.
Before page load is just:
if ("" = "")
for any form submit you could use:
if (Request.ServerVariables("REQUEST_METHOD") = "POST")
The page action does point to the new page but the UE script isn't being triggered. Incidentally, neither is the WA Server Validation script which has the same trigger.
I've changed the UE code to use both before page load and any form submit, and they work! Go figure. I have spent a solid 12 hours on this today so far.
Can you please explain this section for me Ray:
'Send Mail All Entries
if ("contact-confirmation.asp" <> "") then
Response.Redirect("contact-confirmation.asp")
end if
I copied that in from an old CDOSYS / UE script I had on another website, and I've changed the page that's referenced obviously, but I have no idea what this is or what it does?
Also, despite the trigger being changed, it's still not sending to the BCC referenced (my e-mail address).
Tough old slog this one!
NJ
That code is to redirect to another page after sending the email. It checks to see if you have a redirect page set and then redirects if you do.
Ray, is there a way to specify more than one e-mail address in the CC Entries section? I've currently got...
'CC Entries
set WA_MailObject = WAUE_AddCC(WA_MailObject,"admin@gallowayheathers.com")
MailCC = gAddCC
Thank you.
NJ
You should be able to just repeat that line of code:
set WA_MailObject = WAUE_AddCC(WA_MailObject,"second@gallowayheathers.com")
