Google ProMaps - Does not work with PHP7.1
Thread begun 1/29/2018 11:13 am by Steve | Last modified 1/29/2018 5:04 pm by Ray Borduin | 3653 views | 9 replies |
Steve
FYI Google ProMaps does not work with PHP 7.1
Had to move a site back to PHP 5.6 which does work but would prefer to use 7.1 since the rest of the site works fine with the new PHP version.
The code should be all javascript, so I can't imagine why it wouldn't work in php7. If you could give me a sample I could take a look and debug it.
Steve
Some screen shots that show this condition...
Can I get a url and FTP access to a non-working page? I don't think it is related to the php version, but I'd need to debug to find the cause.
Steve
FTP Credentials created
That page appears to be working. Do you have a link to a page that doesn't work that I can debug?
Steve
That's a tough one Ray as I need change the Mapping to PHP 7.2 which will cause the current page to also fail. I'll do so now and hope no one notices. Just let me know when we are clear to move back.
It is a strange issue where it isn't finding the file when referenced with an absolute path.
This wouldn't work:
<?php require_once("/webassist/google_javascript/wagmp_map_1.php"); ?>
but this does:
<?php require_once("webassist/google_javascript/wagmp_map_1.php"); ?>
I'm not sure why the absolute path works in other php versions but not this one.
Steve
Yes, it's a new condition I have found since moving to Windows Server 2016 from WS 2012. I've needed to have that trailing slash which could be required due to creating Friendly URLs.
What's odd is that I needed to add the leading slash to peg the file location to the root directory. In the case your referencing, it's only working when that is NOT the case. Very odd.
Thanks for taking the time to look at this Ray.
Steve
Ray,
I found other pages in the same site that had issues related to root leve path references. I've found this is not needed in PHP 7.* even though it was needed in 5.6. Very odd but nice to know what was causing problems.
