Notice: Undefined variable: WA_Authorize_Net_API_Credentials_x_test_request
Thread begun 1/28/2018 10:47 pm by lee365928 | Last modified 1/30/2018 9:29 am by Ray Borduin | 5495 views | 12 replies |
lee365928
I recently updated my site from mysql to mysqli. Now I'm getting the following error when I place an order. The order does get sent to and approved by authorize.net, but I don't get an email receipt from my site and I get this error rather than the checkout success page.
Notice: Undefined variable: WA_Authorize_Net_API_Credentials_x_test_request in /home4/user/mysite/confirm.php on line 73
Please attach a copy of the page that has the error and I can take a look. I may need FTP access and a url to fully debug if I can't spot the problem.
lee365928
Sure.
Simply replacing the connection file will break a lot of things. You need to also update any recordsets, inserts, and update code to use MySQLi.
I would need to see this page:
That is the one with the error.
lee365928
Ok, I've attached it. Thanks.
Can I see a copy of the file:
webassist/ecart/checkout/credentials/gateways.php
That appears to be out of sync with the page. Once I see that I can tell you what to update. Make sure you make the attachment private.
lee365928
here you go.
On line 73 replace:
$WA_Authorize_Net_API_Credentials_x_test_request
with:
$WA_Authorize_Net_API_Credentials_TestMode
I'll look into why it was written wrong when you updated your credentials.
lee365928
Great, thanks. That change let the order go through to the payment gateway. Now I get this error;
Parse error: syntax error, unexpected 'purchases' (T_STRING) in /home4/user/site/webassist/email/waue_5b_1.php on line 52
I looked at line 52 and it's part of the ecart generated code, so I'm not sure. I've attached that file.
The issue appears to be on line 77 of that file. Try updating that line to:
$MailBody = $MailBody . "                    	<img src=\"http://www.fangearlive.com/orderfranciscanalliance/images/garments/".$fangearlive->DisplayInfo("Thumbnail")  ."\"><br />".$fangearlive->DisplayInfo("Name")  ."<br /> Size: " . $fangearlive->DisplayInfo("Size")  ."\r\n";
