Excluding certain items from sitewide discount event
Thread begun 1/24/2018 3:35 pm by graham | Last modified 1/27/2018 1:01 pm by Ray Borduin | 3733 views | 8 replies |
graham
Ray, ages ago we worked on the coding to allow for certain items, as designated by a line like this abs(in_array([ID], array('61','62','63','64','65','66','67')))?[DiscountableD]=1:0 , to be accumulated and identified for discount(s) - works fine when I have a reasonable number of items to be designated. But, what if I wanted a particular discount to apply all but a few items in my inventory? In my example above, assume DiscountableD was going to be every product in my store, except for a small array of productIDs I wanted to exclude ... I could go through and make the line above hold all my product ID's, but it would be more than 100 entries. Can you help me with the logic or shortcut from what I have described?
Thanks as always!!
You could probably do an alternative exclude array just like the include array we did previously. If you give me the code where that is implemented I could probably help you with how to do it. I don't really remember the project we worked on together, but I'm sure I can lend a hand, but I'd have to see the original code.
graham
Thanks for responding, Ray ... you made the coding pretty simple, we set up a new column in the eCart Object e.g. DiscountableD, added the new calculation from above to identify products to be counted/set their setDiscountableD to 1 e.g. abs(in_array([ID], array('61','62','63','64','65','66','67')))?[DiscountableD]=1:0, and created the discount rule (25% off here):
$totalDiscount = 0;
if (true && ($this->ConditionalTotal("Quantity", "DiscountableD", "1") > 0)) {
$totalDiscount += ($this->ConditionalTotal("TotalPrice", "DiscountableD", "1") * .25);//Result
return WA_eCart_FormatNumber($totalDiscount, $this->ForceDecimalsC, $this->DecimalPlacesC);
I just don't see the easy way to inverse this? Does this snippet help describe my issue better?
Do you want to continue using the old one and have a new discount group with other products applicable, or are you replacing the old one?
graham
replace, I think ... against your previous advice, maybe given in a long-ago screenshare, I have never deleted any of my discount rules, they just lie there inactive ... I am up to DiscountableP now :)
You could just add an exclamation point to do the opposite... for instance:
abs(!in_array([ID], array('61','62','63','64','65','66','67')))?[DiscountableD]=1:0
graham
really ... that simple? :s I need to brush up a bit ... thanks, Ray! May get in touch with you for a support session to replace Paypal with Square in my revised website ... maybe in February. Take care0
However, is it difficult to limit a valid itemID to only 1 unit? If 2 are ordered, only 1 qualifies in the DiscountableO total for 20% off ... the other stay in cart at full price.
You should be able to base the discount on the Price field instead of the TotalPrice if you only want it to apply to the first. If you mean the first item of the cart then it can be a bit more difficult and would probably require a premier support ticket.
graham
Working on a weekend? :) Thanks for responding, Ray. Of course, as I stood back for a minute, I realized I was making my issue too complicated .. I simply adding the product ID to the array of "not included" and created a unique discount for the product(s) I wanted to control the quantity of ... I am sure there is a more exotic solution, but this works. Again, thanks for responding, Ray.
