How to clear Insert session ID on page reload
Thread begun 1/24/2018 3:28 am by Accumike | Last modified 1/31/2018 9:27 am by Ray Borduin | 2226 views | 5 replies |
Accumike
Hi Ray
I have an insert sb that redirects to another page to add some additional info automatically for the user. This uses the session ID variable created by the insert sb as part of the URL string, as follows:
... "&id_act=" . $_SESSION['id_act'] ...
This works correctly.
However, when I go back to the first form page and add another record with the insert sb, the URL string picks up the earlier session ID variable, not the latest.
I tried this unset($GLOBALS['id_act']) code at the start of the insert sb, but it does not seem to work:
if (isset($_POST["WA_Insert1"]) || isset($_POST["WA_Insert1_x"])) {
// Clear any earlier id_act SESSION value
unset($GLOBALS['id_act']);
$InsertQuery = new WA_MySQLi_Query($crm_realpress_wa);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "cu_action_act";
$InsertQuery->bindColumn("idlic_act", "i", "".((isset($_POST["idlic_act"]))?$_POST["idlic_act"]:"") ."", "WA_DEFAULT");
etc...
How should I clear the earlier session ID variable reliably?
Michael
unset($_SESSION['id_act']);
Would be the correct code to clear it. However it should be updated with the insert, so I think there is another underlying problem that needs to be fixed. Removing the session variable won't help the problem that the session variable isn't being stored properly.
Accumike
Thanks Ray, I'll investigate further.
Accumike
Hi Ray
This is what I'm doing – the following is part of a CRM:
I am using the same table (cu_action_act) to store a calendar event, then optional meta information about certain events. I use the same table because my customer wants to track a timeline for each contact on the CRM.
When the crm user inserts the calendar event, the page either returns to display the event (at event.php), or if a particular type of event is inserted the page redirects to another, hidden page (timeline_steps.php), which automatically inserts a further record in cu_action_act, using the session id (id_act) from the first transaction as a key:
$InsertQuery->saveInSession("id_act");
The second transaction does NOT create a session id, as this is not needed:
$InsertQuery->saveInSession("");
On creation of the second record, the timeline_steps.php page redirects back to event.php
Several events may be inserted in succession, following this process.
Would it be advisable to create a session id in the second transaction? Would this then clear the incorrect session id in event.php?
Hope this is clear.
The part I don't understand is why you need to delete the old session variable. I don't understand the problem with your current configuration.
Accumike
The session variable 'id_act' is used as part of the URL string when the page redirects. I found that it was picking up the penultimate value for 'id_act', therefore I assumed that the session variable needed to be deleted, so that the latest value for 'id_act' would be used.
I agree that this is unexpected behaviour, so I am going to review my overall process. I suggest that you close this support item, I'll get back to you if I still have a problem.
