insert in database working but file not uploaded
Thread begun 1/24/2018 2:17 am by Ashok | Last modified 1/24/2018 11:23 am by Ray Borduin | 888 views | 1 replies |
Ashok
Hello,
I am using insert query with an image file upload. The insert is working but file name is not inserted in db, nor the image is uploaded in destination folder.
<?php require_once('../Connections/bimpra.php'); ?>
<?php require_once("../webassist/ckeditor/ckeditor.php"); ?>
<?php require_once('../webassist/mysqli/rsobj.php'); ?>
<?php require_once("../webassist/file_manipulation/helperphp.php"); ?>
<?php require_once('../webassist/mysqli/queryobj.php'); ?>
<?php require_once('../webassist/mysqli/authentication.php'); ?>
if ("" == "") {
$RestrictAccess = new WA_MySQLi_Auth();
$RestrictAccess->Action = "restrict";
$RestrictAccess->Name = "user";
$RestricAccessRedirect = "login.php";
if (function_exists("rel2abs")) $RestricAccessRedirect = $RestricAccessRedirect?rel2abs($RestricAccessRedirect,dirname(__FILE__)):"";
$RestrictAccess->FailRedirect = $RestricAccessRedirect;
$RestrictAccess->execute();
$user = new WA_MySQLi_RS("user",$bimpra,0);
$user->setQuery("SELECT * FROM users");
$user->execute();?>
$blogcity = new WA_MySQLi_RS("blogcity",$bimpra,0);
$blogcity->setQuery("SELECT * FROM blog_city ORDER BY id ASC");
$blogcity->execute();?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../file/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "4",
'ResizeWidth' => "570",
'ResizeHeight' => "370",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "pic1", "0", "", "true", $WA_UploadResult1_Params);
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$InsertQuery = new WA_MySQLi_Query($bimpra);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "blog_article";
$InsertQuery->bindColumn("city", "s", "".((isset($_POST["city"]))?$_POST["city"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("metatitle", "s", "".((isset($_POST["metatitle"]))?$_POST["metatitle"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("metakeywords", "s", "".((isset($_POST["metakeywords"]))?$_POST["metakeywords"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("metadescription", "s", "".((isset($_POST["metadescription"]))?$_POST["metadescription"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("blogtitle", "s", "".((isset($_POST["blogtitle"]))?$_POST["blogtitle"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("translit", "s", "".((isset($_POST["translit"]))?$_POST["translit"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("dateposted", "s", "".((isset($_POST["dateposted"]))?$_POST["dateposted"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("writer", "s", "".((isset($_POST["writer"]))?$_POST["writer"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("article", "s", "".((isset($_POST["article"]))?$_POST["article"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("pic1", "s", "".((isset($_FILES["pic1"]))?$_FILES["pic1"]["name"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("active", "i", "".((isset($_POST["active"]))?$_POST["active"]:"") ."", "WA_DEFAULT");
$InsertQuery->saveInSession("");
$InsertQuery->execute();
$InsertGoTo = "blogarticle.php";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
<!DOCTYPE html>
<html lang="ru">
<head>
<!-- SITE TITTLE -->
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1">
<title>Админ Панель - Бимпра</title>
<!-- PLUGINS CSS STYLE -->
<link href="../plugins/jquery-ui.css" rel="stylesheet" type="text/css">
<link href="../plugins/bootstrap/css/bootstrap.min.css" rel="stylesheet">
<link href="../plugins/font-awesome/css/font-awesome.min.css" rel="stylesheet">
<link rel="stylesheet" type="text/css" href="../plugins/rs-plugin/css/settings.css" media="screen">
<link rel="stylesheet" type="text/css" href="../plugins/selectbox/select_option1.css">
<link rel="stylesheet" type="text/css" href="../plugins/datepicker/datepicker.css">
<link rel="stylesheet" type="text/css" href="../plugins/isotope/jquery.fancybox.css">
<link rel="stylesheet" type="text/css" href="../plugins/isotope/isotope.css">
<!-- GOOGLE FONT -->
<link href='https://fonts.googleapis.com/css?family=Montserrat:400,700' rel='stylesheet' type='text/css'>
<!-- CUSTOM CSS -->
<link href="../css/style.css" rel="stylesheet">
<link rel="stylesheet" href="../css/colors/default.css" id="option_color">
<!-- FAVICON -->
<link rel="shortcut icon" type="image/png" href="../img/favicon.png"/>
<!-- HTML5 shim and Respond.js for IE8 support of HTML5 elements and media queries -->
<!-- WARNING: Respond.js doesn't work if you view the page via file:// -->
<!--[if lt IE 9]>
<script src="https://oss.maxcdn.com/html5shiv/3.7.2/html5shiv.min.js"></script>
<script src="https://oss.maxcdn.com/respond/1.4.2/respond.min.js"></script>
<![endif]-->
<link type="text/css" href="../webassist/datepicker/addarticle_datepicker_1/jquery-ui.css" rel="stylesheet" />
<script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
</script>
<script src="//ajax.googleapis.com/ajax/libs/jqueryui/1/jquery-ui.min.js"></script>
$(function(){
$('#datepicker_1').datepicker({
dateFormat: 'dd/mm/yy',
showAnim: 'show',
onClose: closeDatePicker_datepicker_1
function closeDatePicker_datepicker_1() {
var tElm = $('#datepicker_1');
if (typeof datepicker_1_Spry != null && typeof datepicker_1_Spry != "undefined" && dateposted_Spry.validate) {
datepicker_1_Spry.validate();
tElm.blur();
</script>
</head>
<body>
<div class="main-wrapper">
<!-- HEADER -->
<header>
<?php include('nav.php'); ?>
</header>
<!-- PAGE TITLE -->
<section class="pageTitle" style="background-image:url(../img/pages/page-title-bg9.jpg);">
<div class="container">
<div class="row">
<div class="col-xs-12">
<div class="titleTable">
<div class="titleTableInner">
<div class="pageTitleInfo">
<h1>Админ Панель</h1>
<div class="under-border"></div>
</div>
</div>
</div>
</div>
</div>
</div>
</section>
<!-- PAGE CONTENT -->
<section class="mainContentSection blogSidebar">
<div class="row">
<div class="col-sm-12 col-xs-12">
<div class="thumbnail blogSinglePost">
<div class="caption">
<form action="<?php echo htmlspecialchars($_SERVER["PHP_SELF"]);?>" method="POST" role="form" class="form">
<div class="form-group">
<h2>ADD BLOG ARTICLE</h2>
</div>
<div class="form-group"> City
<select name="city">
while(!$blogcity->atEnd()) {
<option value="<?php echo($blogcity->getColumnVal("city")); ?>"><?php echo($blogcity->getColumnVal("city")); ?></option>
$blogcity->moveNext();
$blogcity->moveFirst(); //return RS to first record
?></select>
</div>
Meta Title<input type="text" class="form-control" id="metatitle" name="metatitle" placeholder="Meta Title">
</div>
Meta Keywords <input type="text" class="form-control" id="metakeywords" name="metakeywords" placeholder="Meta Keywords">
</div>
Meta Description <input type="text" class="form-control" id="metadescription" name="metadescription" placeholder="Meta Description" >
</div>
Blog Title<input type="text" class="form-control" id="blogtitle" name="blogtitle" placeholder="Blog Title" >
</div>
Translit <input type="text" class="form-control" id="translit" name="translit" placeholder="Translit">
</div>
Date
<input id="datepicker_1" name="dateposted" type="text" />
</div>
Author <input type="text" class="form-control" id="writer" name="writer" placeholder="Writer" >
</div>
<div class="form-group"> Article
// The initial value to be displayed in the editor.
$CKEditor_initialValue = "";
$CKEditor = new CKEditor();
$CKEditor->basePath = "../webassist/ckeditor/";
$CKEditor_config = array();
$CKEditor_config["wa_preset_name"] = "No File Management";
$CKEditor_config["wa_preset_file"] = "NoFileManagement.xml";
$CKEditor_config["width"] = "100%";
$CKEditor_config["height"] = "200px";
$CKEditor_config["dialog_startupFocusTab"] = false;
$CKEditor_config["fullPage"] = false;
$CKEditor_config["tabSpaces"] = 4;
$CKEditor_config["toolbar"] = array(
array( 'Source','-','Save','NewPage','Preview','-','Templates'),
array( 'Cut','Copy','Paste','PasteText','PasteFromWord','-','Print','SpellChecker','Scayt'),
array( 'Undo','Redo','-','Find','Replace','-','SelectAll','RemoveFormat'),
array( 'Form','Checkbox','Radio','TextField','Textarea','Select','Button','ImageButton','HiddenField'),
array( 'BidiLtr','BidiRtl'),
array( 'Bold','Italic','Underline','Strike','-','Subscript','Superscript'),
array( 'NumberedList','BulletedList','-','Outdent','Indent','Blockquote','CreateDiv'),
array( 'JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock'),
array( 'Link','Unlink','Anchor'),
array( 'Image','Flash','Table','HorizontalRule','Smiley','SpecialChar','PageBreak'),
array( 'Styles','Format','Font','FontSize'),
array( 'TextColor','BGColor'),
array( 'Maximize','ShowBlocks','-','About'));
$CKEditor_config["contentsLangDirection"] = "ltr";
$CKEditor_config["entities"] = false;
$CKEditor_config["pasteFromWordRemoveFontStyles"] = false;
$CKEditor_config["pasteFromWordRemoveStyles"] = false;
$CKEditor->editor("article", $CKEditor_initialValue, $CKEditor_config);
</div>
Pic
<input name="pic1" type="file">
</div>
Active<input name="active" type="checkbox" value="1" checked>
</div>
<button type="submit" name="submit" class="btn buttonCustomPrimary">Add Article</button>
</form>
</div>
</div>
</div>
</div>
</div>
</section>
<!-- FOOTER -->
<?php include('footer.php'); ?>
</div>
<!-- JAVASCRIPTS -->
<script src="https://ajax.googleapis.com/ajax/libs/jquery/1.11.3/jquery.min.js"></script>
<script src="../plugins/jquery-ui/jquery-ui.js"></script>
<script src="../plugins/bootstrap/js/bootstrap.min.js"></script>
<script src="../plugins/rs-plugin/js/jquery.themepunch.tools.min.js"></script>
<script src="../plugins/rs-plugin/js/jquery.themepunch.revolution.min.js"></script>
<script src="../plugins/selectbox/jquery.selectbox-0.1.3.min.js"></script>
<script src="../plugins/datepicker/bootstrap-datepicker.js"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/waypoints/2.0.3/waypoints.min.js"></script>
<script src="../plugins/counter-up/jquery.counterup.min.js"></script>
<script src="../plugins/isotope/isotope.min.js"></script>
<script src="../plugins/isotope/jquery.fancybox.pack.js"></script>
<script src="../plugins/isotope/isotope-triger.js"></script>
<script src="../plugins/countdown/jquery.syotimer.js"></script>
<script src="../js/custom.js"></script>
</body>
</html>
Ashok
SOLVED.
added enctype="multipart/form-data" to <form>
