changing image input to button causes update cart to stop working?
Thread begun 1/19/2018 3:00 am by Nathon Jones Web Design | Last modified 1/24/2018 11:25 am by Ray Borduin | 2112 views | 4 replies |
I have image inputs for the Update button on my view cart page:
<input type="image" name="HeatherCART_Update" src="heather-plants/btn-updatecart.png" onmouseover="this.src='heather-plants/btn-updatecarton.png'" onmouseout="this.src='heather-plants/btn-updatecart.png'" alt="Update Cart" />
I have changed the site to use Bootstrap and want to use a Bootstrap button, instead, for this so I changed the above to:
<button name="HeatherCART_Update" alt="Update Cart" class="btn btn-default">Update</button>
...and now the update behaviour doesn't work? Do I need to change the trigger code, currently...
' WA eCart Update
if (cStr(Request.Form("HeatherCART_Update")) <> "" OR cStr(Request.Form("HeatherCART_Update.x")) <> "") then
set HeatherCART = HeatherCART_UpdateCart(HeatherCART)
Redirect_redirStr=""'_redirStr
if (Redirect_redirStr <> "") then
HeatherCART_redirStr = Redirect_redirStr
end if
HeatherCART_cartAction = "Update"
end if
If so, what do I change it to?
Thank you.
NJ
Maybe you have to give the button tag a value attribute? Try adding: value="update"
Yup, that was it. Cheers Ray.
Ah, it's not working with the WA eCart Store Cart Summary in Db or WA eCart Store Cart Details in Db behaviours now and adding a value attribute isn't fixing it.
Here's the trigger for those behaviours (this is Classic ASP btw):
<%' WA eCart Store Cart Summary in Db
if (cStr(Request.Form("Checkout1.x")) <> "") then
<%' WA eCart Store Cart Details in Db
This is my existing input type image button, which works:
<input name="Checkout1" id="Checkout1" type="image" src="heather-plants/btn-proceedtocheckout.png" onmouseover="this.src='heather-plants/btn-proceedtocheckouton.png'" onmouseout="this.src='heather-plants/btn-proceedtocheckout.png'" />
...and this is what I'm trying to change it to:
<button name="Checkout1" id="Checkout1" type="submit" value="Submit" class="btn btn-lg btn-success" role="button">Proceed to Payment <i class="fa fa-credit-card" aria-hidden="true"></i></button>
The new button (above) simply Refreshes the page.
Hope you can help. Thanks Ray.
NJ
I think you just have to delete the ".x" portion from the triggers.... so it will be:
if (cStr(Request.Form("Checkout1")) <> "") then
