Form text field in repeated selection and server validation
Thread begun 1/17/2018 8:34 am by tony | Last modified 1/19/2018 9:38 am by Ray Borduin | 5339 views | 15 replies |
tony
Hello all,
I have a form with one text field.
I applied the "WA repeat selection" and I duplicate this field X times. Nice.
But all repeated fields have the same ID, so I changed their IDs using the counter from the bindings. It works.
Now I need to server validate them.
How can I server validate these repeating text fields?
TIA
tony
Client Validate is easier ;)
What type of validation do you want on them? Are they all required?
tony
yes,
but there is money involved (it's a cashback). So, I prefer using server validation, just in case someone disable javascript on his browser...
tony
What type of validation? Required? Numeric?
tony
Sorry, my "yes" was for "all required".
They are text fields, basically.
Tony
tony
my 2c.
What if I creater static fields, then apply the Wa server validation and then add the WA repeat selection to the text fields and the WA validation?
Of course I will need to tweak the code a bit.
But I just need to know if there are better ways to do this.
It would be nice to create something similar to this (https://bootsnipp.com/snippets/AXVrV) and then apply the WA logic.
Tony
If you always only have six then you can just add them manually one at a time to the server validation.
Another option is to write a loop to do it, but then you wouldn't be able to re-enter the server validation server behavior.
If you attach a copy of the page you are working on I can give you code samples for each.
tony
Thanks, Ray,
here is attached the step2.php page. Please keep in mind that in step1.php I set a session variable (numart_sess) that holds the number of copies I need to create about the fields Articolo and Barcode in step2. This is decided by the user in step 1 by using a dropdown menu (values range from 1 to 15 maximum).
So, basically, in step 2 I need to get maximum 15 Articolo fields and maximum 15 Barcode fields.
Then I need to validate all fields and save all fields values to session variables. In step3.php page I will display all collected data and save it to database (in a single record).
Thanks again, Ray.
Tony
I'd just add a for loop around both the display and validation and add the increment.
Something like:
if (isset($_POST["next2"]) || isset($_POST["next2_x"]))  {
$WAFV_Redirect = "step2.php";
$_SESSION['WAVT_step2_279_Errors'] = "";
  if (
$WAFV_Redirect == "")  {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
for (
$x=1; $x<=intval($_SESSION['numart_sess']); $x++) {
$WAFV_Errors .= WAValidateRQ(((isset($_POST["articolo_".$x  .""]))?$_POST["articolo".$x  .""]:"") . "",true,$x);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["barcode_".$x  .""]))?$_POST["barcode".$x  .""]:"") . "",true,"2".$x);
  if (
$WAFV_Errors != "")  {
PostResult($WAFV_Redirect,$WAFV_Errors,"step2_279");
and then the display like:
for ($x=1; $x<=intval($_SESSION['numart_sess']); $x++) {
        <div class="form-group">
                    <label for="articolo_<?php echo($x); ?>">Articolo <?php echo($x); ?></label>
                    <input name="articolo_<?php echo($x); ?>" type="text" class="form-control" id="articolo_<?php echo($x); ?>" placeholder="Articolo" value="<?php echo(WA_getSavedFormValue("persist_step2","articolo_".$x  ."")) ?>">
if (ValidatedField('step2_279','step2_279'))  {
  if ((
strpos((",".ValidatedField("step2_279","step2_279").","), "," . "".$x  ."" . ",") !== false || "1" == ""))  {
    if (!(
false))  {
                            <div class="errore_validazione">errore articolo </div>
                            <?php //WAFV_Conditional step2.php step2_279(1:)
        </div>
                    <label for="barcode_<?php echo($x); ?>">barcode <?php echo($x); ?></label>
                    <input name="barcode_<?php echo($x); ?>" type="text" class="form-control" id="barcode_<?php echo($x); ?>" placeholder="barcode" value="<?php echo(WA_getSavedFormValue("persist_step2","barcode_".$x  .")) ?>">
php
  if ((
strpos((",".ValidatedField("step2_279","step2_279").","), "," . "2".$x  ."" . ",") !== false || "2" == ""))  {
    if (!(
false))  {
                                <div class="errore_validazione">errore barcode </div>
                                <?php //WAFV_Conditional step2.php step2_279(2:)
        </div>
tony
Just as information (see below):
[snip]
  if ((strpos((",".ValidatedField("step2_279","step2_279").","), "," . "".$x  ."" . ",") !== false || "1" == ""))  {
[snip]
  if ((strpos((",".ValidatedField("step2_279","step2_279").","), "," . "2".$x  ."" . ",") !== false || "2" == ""))  {
[snip]
But what are those numbers "...) !== false || "1" == "")) {..." and "...) !== false || "2" == "")) {..."?
Have I to change them to:
if ((strpos((",".ValidatedField("step2_279","step2_279").","), "," . "".$x  ."" . ",") !== false || "".$x."" == ""))  {
if ((strpos((",".ValidatedField("step2_279","step2_279").","), "," . "2".$x  ."" . ",") !== false || "2".$x."" == ""))  {
Tony
