Under modify I do not see security assist
Thread begun 1/15/2018 2:18 pm by i.edwards384429 | Last modified 1/17/2018 10:14 am by Ray Borduin | 3097 views | 7 replies |
i.edwards384429
Hi
I am using an old version but when I select modify in the DW menu I do not see the option for Security Assist ---- access rules manager
I'm using DW cc and security assist119
Is there another way of accessing this menu?
thanks
Ian
It should appear in the WebAssist menu under Security Assist
i.edwards384429
Hi Ray
THink I may have more information.
Cookies toolkit installs via the extension manager perfectly but
Security assist brings up the following error
The element DWMenu_modify_selectionProporties cannot be found in C:\users\Ian\Appdata\Roaming\Adobe\Dreamweavercc\en_us\Configurations\Menuss\Menus.xml The extension will not be installed
Although parts of the extensions are being installed because I can run the security assist wizard.
All very confusing
thanks
Ian
all I have under the Web Assist menu is
momento
help
preferences
get more extensions,
I have installed the following having converted them from mxp to xzip
Cookies toollkit
Data assist
Security assist
Dynamic connection
BUT only cookies toolkit is shown in the extension manager.
Under the insert menu I have web assist and the following are listed:
data assist
display cookie
get more extensions
security assist
No where do I see the option to load Access Pages manager
Shall I download, re convert and re install the extensiosn
thanks
Ian
You are using very old versions of the extensions, so I don't really know what the best course of action is. Do you have Design Extender? Would you consider upgrading? I think that is the best option since the versions you are using are more than 5 years old.
i.edwards384429
Thanks Ray
it seems I would have top upgrade to Databridge to get the latest security Assist and Data assist. I know the extensions are five years old asthat was when I retired I'll have to contact the charity I'm working for and see if they will stand the upgrade cost
cheers
Ian
i.edwards384429
Hi Ray
the charity won't pay but I think I'll pay for it myself.
Question please. At the moment I've got my old data assist set up to search the database and that works exactly as I want it.
As you know I now want to set up access restrictions so if I upgrade to the latest data bridge will that effect my exisitng pages based on the old data assit extension ? ie will I have to start from scratch?
thanks
Ian
It should be backwards compatible, so nothing will have to be redone.
i.edwards384429
Thanks I'll add it to my todo list tomorrow
cheers
Ian
