access to c:\users\...\appdata\roaming\adobe\dreamweaver cc 2014.1\en_US\Configuration\Floaters\WA_Processor was denied
Thread begun 1/10/2018 5:42 pm by Francois | Last modified 1/12/2018 8:22 am by Ray Borduin | 1378 views | 2 replies |
Francois
the folder is empty. I removed all extensions, with errors. I replaced the WA_uninstall.htm and WA_uninstall2.htm in the Commands folder and the WA_Installer.html and WA_Installer2.html in the Floaters folder (I downloaded them from the post on WA Archive.zip) and also deleted the Configuration\WinFileCache-xxx.dat
running DW CC 2014.1 on Win 10 - should I uninstall it too?
Are you trying to remove all of your installed extensions? If so the best option might be to just delete the Configuration folder entirely and DW will recreate it with the default options on the next startup.
Since that is a floater error it might be that you just have to go to window->Workspace Layout->Reset 'your layout'
Francois
I uninstalled all extensions, DW too, deleted the Config folder, reinstalled all and seems to be working better now. Thank you.
