Is there an update for Dreamweaver CC for this tutorial: http://www.webassist.com/tutorials/Create-new-pages-from-PowerCMS-templates
Thread begun 1/09/2018 1:01 pm by russb335115 | Last modified 1/13/2018 9:11 am by Ray Borduin | 4287 views | 9 replies |
russb335115
When added the repeat region it is only repeating the last blog. I notice the the repeat region is different in CC. Here is what is produces.
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_RobynMealRS){
And closes with:
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_RobynMealRS && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$row_RobynMealRS = mysql_fetch_assoc($RobynMealRS);
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
That looks like you used "Repeat Selection" server behavior instead of "Repeat Region"... that is the difference in the code, but they should work similarly. Repeat selection just has a few more options that allow you to use it nested inside a repeat region to repeat rows and columns.
russb335115
Do you have any idea why its just repeating the first blog info and not the second.
russb335115
Also, I'm getting this error when I try to login to the CMS:
http://blank1.iknowawebguy.com/admin_cms/users_login.php?failed=1&failed=1&accesscheck=%2Fadmin_cms%2Findex.php%3F
That implies you are either using the wrong username and password or your server isn't configured properly to save session values. I'd need FTP access to debug it.
russb335115
Thanks Ray, I did figure that out by looking at the database. Did you have any feedback as to why the repeat region is only showing the one blog title and content on the results page? I will leave a link in the PM box if you want to take a look.
I'd need ftp access to be able to tell.
russb335115
Thanks Ray, see PM.
You had:
$row_RobynMeal['ContentPageSetOrder']
instead of:
$row_RobynMealRS['ContentPageSetOrder']
I updated that and the new content appears.
russb335115
Awesome, thanks Ray. I kept looking for the missing ingredient but couldn't make the connection.
