Checkout not opening Payment Options if Shipping or Billing Country is not United States
Thread begun 1/02/2018 8:37 am by joerg431091 | Last modified 1/02/2018 11:40 am by Ray Borduin | 5213 views | 8 replies |
joerg431091
Hello,
I just opened up several countries for shipping and billing options in the checkout section. My problem is that the checkout page is not changing/opening the Payment options if either the Shipping or the Billing Country is set to anything but the United States.
Any advice would be appreciated.
Thanks a lot and happy new year.
Joerg
I'd have to look at the page to debug this. There isn't enough information in the post to identify the problem. I'd at least need a url to see the code that doesn't' work. I may need FTP access if the problem is in the PHP.
joerg431091
Hi Ray,
Wow you are fast. Thanks a lot. I was just about to send an update.
Sorry I forgot the URL = www.navariniusa.com
I noticed that it does work if you put something into the State text field that opens up once a different country is chosen. So this information seems to be set to "required" although there is no asterisk on the state text field. Is there a way to not make the state field an requirement for countries outside the US.
Thanks again.
Joerg
If you attach a copy of the confirm_cart.php page I can show you what lines to update to make the state field not required for outside of the US.
joerg431091
Copy is attached. Update: Besides showing me how to make the field not required, can you also show me how to add an asterisk so I have both options in case I want to leave it required?
Thanks so much.
Joerg
You can update line 32 from:
$WAFV_Errors .= WAValidateRQ((isset($_POST["State"])?$_POST["State"]:"") . "",true,7);
$WAFV_Errors .= WAValidateRQ((($_POST["Country"]=="US")?$_POST["State"]:"N/A") . "",true,7);
That will ignore the validation if the Country isn't set to US.
In order to keep the field required you would have to update the javascript file:
webassist/ecart/checkout/js/paymentoptions.js
You would comment out or remove these three lines:
var reqText = (reqIndex >= 0)?labelText.substring(reqIndex).replace(/"/g,"""):"";
stateLabel.attr("rel",reqText);
if (reqIndex >= 0) stateLabel.html(labelText.substring(0,reqIndex));
Then you would add this in its place:
newState.setAttribute("required","true");
joerg431091
Great. Thanks. Am I correct in that I have to do this also in line 42 accordingly?
Such as:
$WAFV_Errors .= WAValidateRQ((isset($_POST["State_2"])?$_POST["State_2"]:"") . "",true,16);
into:
$WAFV_Errors .= WAValidateRQ((($_POST["Country"]=="US")?$_POST["State_2"]:"N/A") . "",true,16);
Yes, but it should use Country_2 like:
$WAFV_Errors .= WAValidateRQ((($_POST["Country_2"]=="US")?$_POST["State_2"]:"N/A") . "",true,16);
joerg431091
Perfect as always!!!
Thanks so much and all the best for 2018!!!!
