delete button changing all rows' column content
Thread begun 1/02/2018 5:39 am by Jamie | Last modified 1/02/2018 11:40 am by Ray Borduin | 2575 views | 6 replies |
Jamie
Hi Ray and Happy New Year!
On the attached update page, there is a 'delete' button which, when clicked, replaces the contents of the PageImage column to 'noimage' - the problem is that clicking the delete button changes all rows PageImage column to noimage when it should be just the row that is selected for that update.
not sure wht I have done wrong?
Cheers
Jamie
It looks like it would work.
Try adding some debug code after line 202 like:
die($WA_Sql);
That is the SQL statement running and it might explain why all rows are updated.
Jamie
thanks Ray
am getting
UPDATE `service_contents` SET `PageImage` = 'noimage' WHERE `PageImage`='bg-slider-service-balance.jpg'
at the moment, all PageImages are using the same image bg-slider-service-balance.jpg although the client has the ability to update each individual row if they so choose
So that is why. You should be using the autonumber column as the unique field in your update statement and when setting the value of the DeleteImage hidden field. You can update that manually on lines 181 and 484.
Jamie
gotcha...have made that chanege but its not actually replacing the PageImage column with 'noimage' - it actually doesnt look to be be doing anything ?
have attached the updated page
It looks right.... write the SQL statement to the page again like you did before and see if it looks right. View source on the page and make sure that the hidden field is populated properly.
Jamie
got it thanks
needed to change
$WA_indexField = "PageImage";
$WA_fieldNamesStr = "ServicesID";
to
$WA_indexField = "ServicesID";
$WA_fieldNamesStr = "PageImage";
all working now
