This is the error that I'm getting: Warning: Unknown: open(/home/content/35/2405535/tmp/sess_pk041uvfr3ik2eiac2o7aup4c3, O_RDWR) failed: No such file or directory (2) in Unknown on line 0 Warning: Unknown: Failed to write session data (files). Pleas
Thread begun 12/28/2017 7:16 pm by elewis93815 | Last modified 1/17/2018 7:12 pm by Ray Borduin | 3861 views | 9 replies |
elewis93815
This is the error that I'm getting: Warning: Unknown: open(/home/content/35/2405535/tmp/sess_pk041uvfr3ik2eiac2o7aup4c3, O_RDWR) failed: No such file or directory (2) in Unknown on line 0 Warning: Unknown: Failed to write session data (files). Please veri
This is the error that I'm getting when I try to add a product to my cart: Warning: Unknown: open(/home/content/35/2405535/tmp/sess_pk041uvfr3ik2eiac2o7aup4c3, O_RDWR) failed: No such file or directory (2) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct () in Unknown on line 0
the url is www.yastylus.com/shop.php
It is probably an issue with your php.ini file and the session_save_path setting pointing to a folder that either doesn't exist or doesn't have proper read/write privileges. Show the message to your hosting provider and they should be able to solve it for you.
  Hi Ray, I just spoke to godaddy about this issue and they said that I should talk to you about the possibility of a file being missing and to speak to the developer about a fix?
Unfortunately a lot of the support people you get in touch with don't understand what is going on. If you give them more information than they need, like telling them you are using a third party shopping cart, it makes it too easy for them to pass the buck.
Just create a new blank page with this code:
@session_start();
$_SESSION['savetest'] = "working";
Then create a new blank page with this code:
@session_start();
var_dump($_SESSION['savetest']);
Visit the first page and then go to the second page. It should show the session variable "savetest" has the value "working".
It it doesn't, show that to GoDaddy and they won't be able to pass the buck because the code is so simple you can see that the session variables aren't being set properly. You probably just got a bad support person.
elewis93815
Hi again! I spoke to GoDaddy and they informed me that they did an upgrade / migration of our hosting server and thought that the problem may be in the version of php ??? I've attached all of the files, not sure if this is just another hand off on there part or not so I thought I'd send everything and see if we can take care of it from there. Thank for your help
The problem is probably exactly what I said it was originally. The value of the session_save_path in the php.ini file is set to a non-existent directory or the directory doesn't have the proper privileges.
Did you use the steps and code I outlined above? What was the result? Can I see the url to the test pages I suggested you create?
elewis93815
I went to the first page, this is what i got:
Warning: Unknown: open(/home/content/35/2405535/tmp/sess_i0cftkdi2ep7t88ps7jtt5h4c4, O_RDWR) failed: No such file or directory (2) in Unknown on line 0
Then to the second page and got this:
NULL
Not sure if this is what was suppose to happen but these are the results. GoDaddy has been unhelpful to say the least. Thanks for your help!
The issue is exactly what the error says the issue is:
session.save_path has a bad value in the php.ini file. You will need to contact godaddy support and have them address it.
Don't give them any background information that might confuse them. Just show them the two extremely simple pages I had you make and they should be able to fix it for you. I've seen this dozens of times on GoDaddy and they always fix it once the problem is clearly identified to them.
elewis93815
Thanks Ray, I'll contact them!
elewis93815
Can you tell me what version of eCart we have? Our GoDaddy hosting account is set up on a php version of 5.2 which seems outdated. The GoDaddy rep I spoke to thought that the language version could be a problem. I shared with him the two pages that you had us create and he looked at the php.ini file and didn't see any issues or any permissions that were missing. He said that when the hosting account migrated to a different server on Dec 26th that may have messed up the ability to use the php 5.2 version. Im not sure if any of this makes sense, however, that is what we are being told. Thanks again for your help!
The two pages I had you create should demonstrate the problem outside of eCart. There is no way the issue can be eCart or the php version.
You shouldn't be discussing eCart or anything else other than the two sample pages with the tech so that they don't get confused. The issue is that the session_save_path is set to a directory that either doesn't exist or have the proper permissions.
Only show the tech the two pages that demonstrate the problem in the fewest lines of code possible. They shouldn't be able to deflect it that way and claim it is an eCart or php issue.
