WA Bindings Panel Crashing on refresh
Thread begun 12/27/2017 10:56 am by Ian Sheldon | Last modified 4/10/2018 3:57 pm by Ray Borduin | 3401 views | 5 replies |
Ian Sheldon
Hi Ray,
Merry Christmas and a Happy New Year.
I am still having problems with the new bindings panel crashing when the refresh button is pressed. It does work on the first time fired when I launch Dreamweaver but subsequent clicks seem to bomb out Dreamweaver.
I'm using a Mac with Dreamweaver 18 (CC 2018)
Cheers,
Ian
It seems to be a dreamweaver issue when trying to do too much at once. I'll try adding a longer timeout between pressing the refresh, updating the list, and displaying it. That is what I did to solve the problem in the first place, but maybe I didn't make it long enough.
Ian Sheldon
Hi Ray,
The crash does seem to still randomly happen when refreshing the bindings from the WA Bindings screen. I can't work out any logic to it. It happens on two different machines.
Cheers
Ian
Thanks for the bug report. That appears to be a timing thing as well. I had reproduced that crash and added a timeout to wait a second before showing the results after a refresh and that appeared to work. Maybe I should extend it to 2 seconds on MAC. This is MAC correct? That was where I originally saw the problem.
Ian Sheldon
Hi Ray,
Thanks for the reply! Hope you are well?
Yes, its the MAC version of DW where I am experiencing the crash.
Cheers,
Ian
Thanks for the bug report. I'll add a configurable delay so people can adjust it if they experience crashes.
