Email is not being received by indicated persons
Thread begun 12/24/2017 8:00 pm by michaelf0199272 | Last modified 2/21/2018 10:17 am by Ray Borduin | 5879 views | 27 replies |
michaelf0199272
Email message is not being received by indicated recipients/persons. Every other thing seems to work, thanks.html page displayed after the "Send Message" request. No error message received. But at the same time no email is received.
http://attorneyhabib.com/contact.php
Also how can I modify the map on the contact form/page to show local map (Dallas map)?
Thanks.
billium99
This post has been deleted.
I'd need to look at the page to debug. Can you give me FTP access and a URL where I can reproduce the problem?
michaelf0199272
please review the answer to your request as a "private message".
On line 54 you had:
include("../webassist/email/waue_contact_1.php");
but the actual path is:
include("webassist/email/waue_contact_1.php");
I updated that line and the email seems to send now.
michaelf0199272
now the email is working --- it is sending and recipients are receiving it. But there is a new problem --- no contents came with the received email. Please see attached image.
Form elements need to have a name attribute or they won't be included in the form submit. Just add name="fieldname" values to your form elements and it should fix the problem.
michaelf0199272
Email information is not being received by indicated persons
I added the attributes, at least I hope I did --- it still did not seem to send form information to recipients.
<input type="text" class="form-control" placeholder="Full name" value="" size="30" maxlenght="35"/>
should be:
<input name="Full_name" type="text" class="form-control" placeholder="Full name" value="" size="30" maxlenght="35"/>
Use underscores instead of spaces in the name attribute.
michaelf0199272
my email/comment form is not working --- I personally think I screwed it up
email does not appear to be sending
