session variable not stored ??
Thread begun 12/22/2017 2:16 am by CraigR | Last modified 12/28/2017 10:15 am by Ray Borduin | 3227 views | 6 replies |
CraigRBeta Tester
My site no longer seems to store my login session values, (ok locally)
I have tried var_dump($_SESSION); on my testing server I get what I expect
array(4) {
["WAENCRYPTEDRETURNUSED"]=>
bool(false)
["WAENCRYPTEDRETURNSUCCESS"]=>
bool(false)
["ContactID"]=>
int(xxxxx)
["userLevel"]=>
int(1)
but on my live server, I only see
array(2) {
bool(false)
bool(false)
Check the session_save_path value from the php.ini file. It may be set to a non-existent folder or a folder without the proper permissions.
CraigRBeta Tester
thanks Ray.
I did think of that, and had my hosting provider change php.ini as the value was now missing.
The folder has 755 permissions, but I wondered - if the folder was the problem, how come 2 of the 4 values were present ?
Yes good point. It must be something else. If you give me FTP access and a URL to reproduce the problem I can debug it and let you know.
CraigRBeta Tester
PM
You have a php.ini file in the root that appears to be causing the problem. Deleting that file seems to have fixed it.
CraigRBeta Tester
PM
