Code for allowing uploads as current iteration fails
Thread begun 12/10/2017 10:37 am by Steve | Last modified 12/11/2017 7:59 am by Ray Borduin | 1043 views | 1 replies |
Steve
Can someone post the actual code snippet when the html editor is set to allow uploads?
While I have the latest version it fails to recognize a database connection (MySQLi).
Probably due to being outdated and needing the old method of MySQL connectivity...
Create a mysql connection and that will allow you to use it in this interface. The code doesn't actually use the mysql connection. It just uses that file to get the database name, username, and password.
