Any issues with Update or Insert via a Bootstrap 4 modal?
Thread begun 12/06/2017 6:37 pm by Steve | Last modified 7/13/2018 10:00 am by Ray Borduin | 2260 views | 5 replies |
Steve
Any know issues using a Modal to post either an Update or Insert on the same page that spawns the modal?
I tried this earlier in the day and could not get it to work but would like to know if it was just my code or if there is a disconnect when a modal is used to take input values and submit as a form.
I know it can be done. I'm not sure what the issue is unfortunately. If you need help I'm sure I can debug it and get it working in a premier support ticket.
Jeff
Can't update records using Bootstrap Modal
Hi Ray
I having been trying to setup a bootstrap modal to pull the records from the database and update the record.
the records are being pulled from the database but when I change the records and click save no changes are made to the records.
Please assist me
It appears that this would work to me. If you give me a URL to reproduce and FTP access I can debug it to see why it isn't working.
Jeff
Hi Ray,
I have sent you the url and the ftp
I've fixed the page.
You were missing an </form> tag, and the hidden field: WADAUpdateRecordID was set to $_GET['Att_ID']... that value wasn't set, so I set it to: $row_WADAattendence["Att_Id"]
Now the page appears to be working. It didn't have anything to do with bootstrap.
