vertical menu big space in between
Thread begun 12/06/2017 10:26 am by alexcubs413730 | Last modified 12/08/2017 6:02 pm by Ray Borduin | 2122 views | 6 replies |
alexcubs413730
I have big gaps in between each drop-down menu.
If you send me a url to view the page I can tell you the CSS to update in order to remove it.
alexcubs413730
Ok, Please check your PM.
It looks like an issue with chrome and how it displays list items. If you update menu.css and add:
display:block;
to the class:
#cssmw li
That should correct the problem.
alexcubs413730
Ok, this is what I found. Where do I add this code?
webroot / CSSMenuWriter / cssmw / menu.css
ul#cssmw {
cursor: default;
list-style-type: none;
margin: 0 0 0 0;
padding: 0 0 0 0;
ul#cssmw ul {
cursor: default;
margin: 0 0 0 0;
padding: 0 0 0 0;
ul#cssmw ul li {
background-image: none;
float: none;
ul#cssmw li {
float: left;
padding: 0 0 0 0;
position: relative;
white-space: nowrap;
z-index: 100;
ul#cssmw li ul {
display: none;
top: 0;
ul#cssmw li:hover > ul {
display: block;
position: absolute;
ul#cssmw li.hover > ul {
display: block;
position: absolute;
ul#cssmw li.current > ul {
position: absolute;
ul#cssmw > li {
ul#cssmw > li > a {
background-color: #dadada;
color: #713b8f;
display: block;
font-family: Arial, Helvetica, sans-serif;
font-size: 14px;
font-style: normal;
line-height: 41px;
margin: 0 0 0 0;
padding: 0px 0px 0px 0px;
text-align: center;
text-decoration: none;
width: 152px;
ul#cssmw > li > a:active {
background-color: #3d3d3d;
color: #fff;
ul#cssmw > li:hover > a {
background-color: #bababa;
color: #000;
ul#cssmw > li.hover > a {
color: #000;
ul#cssmw > li.current > a.current {
color: #fff;
Update this:
#cssmw li {
float: left;
overflow: hidden;
to this:
#cssmw li {
float: left;
overflow: hidden;
display:block;
You can update it in the file:
/webassist/plugins/main_menu/menu.css
alexcubs413730
Thank You, Ray, Problem is fix.
