Your PHP server doesn’t MYSQL module loaded ’t mysql_(p)connect functions
Thread begun 12/02/2017 10:44 am by birdscreen398247 | Last modified 12/05/2017 12:59 pm by Ray Borduin | 9759 views | 9 replies |
birdscreen398247
PHP 7, Dreamweaver CC
I get the above message when trying to define a connection using Webassist MysqlI behavior extension.
Have you tried going to Site->Advanced->Remove Connection Scripts?
birdscreen398247
I did that and now I get
"HTTP Error Code 500 Internal server error"
Are you using localhost or a live server? I'd need to debug it. If you set it up on a remote server that I can ftp into I can test it that way and figure out the problem.
birdscreen398247
Here is the remote server info. See private message.
I think the issue is that your folder name was "connections" and it needs to be "Connections". I updated that on the server and created a new connection and was able to test and view the data in Dreamweaver.
birdscreen398247
Unfortunately, that killed all of my other connections to my website. I had changed the folder to lowercase because it is on a Linux server.
I will change it back and check the connections script for case.
Unfortunately Dreamweaver requires an uppercase connections folder. You can fix it in your .htaccess by adding:
RewriteRule ^Connections/(.*) connections/$1 [QSA,L]
that way your connections folder can be lower case.
birdscreen398247
Where in Dreamweaver can I tell it to use the lowercase for the connections folder?
You can't. That is hard coded into dreamweaver. The .htaccess solution I gave above should make it work.
