pass variable in url of $UpdateGoTo line in update record behaviour
Thread begun 11/28/2017 11:40 pm by Bitossi | Last modified 11/29/2017 7:50 pm by Ray Borduin | 3482 views | 8 replies |
Bitossi
pass variable in url of $UpdateGoTo line in Mysqli update record behaviour
I have an update page (update_user.php) where admin can update records. It contains the update record behaviour.
I want to pass the uuid column of the record being updated, inside the url on the $UpdateGoTo line (34) so I used the parameters button in the 'after updating, go to' field in the update record behaviour dialog box to produce line 34.
I can't get the uuid displayed on the resulting page (user_updated.php).
can you help?
Please attach a copy of the page and I can take a look at what might be wrong.
Bitossi
What version of Dreamweaver are you using?
Line 34 should be updated from:
$UpdateGoTo = "user_updated.php?updtdID=\" . echo($Recordset1->getColumnVal(\"uuid\")) . \"";
$UpdateGoTo = "user_updated.php?updtdID=" . ($Recordset1->getColumnVal("uuid")) .  "";
Bitossi
Bitossi
It works! That's brilliant Ray, thank-you very much!
They removed the parameter option from Dreamweaver after CS6, so it creates code in a way that isn't formatted properly with the extension that has been updated for more recent versions.
Bitossi
So if I upgrade to Dreamweaver cc it should work fine?
Well... there won't be a way to add a parameter. So that won't be broken it just won't exist. They didn't add functionality to replace it.
