Error in server behavior eCart Object: the participant's property is not an array, or the elements in the array are not nodes in the document.
Thread begun 11/13/2017 6:55 am by acornist | Last modified 11/15/2017 6:21 am by Ray Borduin | 1534 views | 1 replies |
acornistBeta Tester
This error pops up frequently, though it does not seem to cause a problem in anything I'm doing.
I'll keep my eye out for it. I haven't seen that error yet, but it shouldn't cause any problems if you just ignore it. If you have a site or files that seem to cause the issue you can share that would help. The key is to reproduce a problem and at that point they are usually pretty straightforward to solve.
