validations
Thread begun 11/13/2017 6:29 am by Jamie | Last modified 11/14/2017 11:02 am by Ray Borduin | 934 views | 2 replies |
Jamie
validations
Hey Ray
Have a form where I am using validations and trying to create multiple options of messages depending on which input is blank / not blank
Basically, if both the first name or last name fields on the form are empty, I want the error message to say 'neither the first name nor last name can be blank'
but if one of the 2 fields has content, then I want the message to say 'first name cannot be blank' (or last name if the last name is blank and first name has content)
I *think* I am going wrong with the 2 <?php } else ?> but am not sure how to get them to work
if (ValidatedField('contact_522','contact_522')) {
if ((strpos((",".ValidatedField("contact_522","contact_522").","), "," . "1" . ",") !== false || "1" == "") || (strpos((",".ValidatedField("contact_522","contact_522").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
<span class="text-element elementRequired">
if ((strpos((",".ValidatedField("contact_522","contact_522").","), "," . "1" . ",") !== false || "1" == "") && (strpos((",".ValidatedField("contact_522","contact_522").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
neither
<?php //WAFV_Conditional contact.php contact_522(1,2:)
if ((strpos((",".ValidatedField("contact_522","contact_522").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
first name
<?php //WAFV_Conditional contact.php contact_522(1:)
if (!(false)) {
nor
<php } else { ?>
or
if ((strpos((",".ValidatedField("contact_522","contact_522").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
last name
<?php //WAFV_Conditional contact.php contact_522(2:)
if (!(false)) {
can
<php } else { ?>
cannot
be blank </span>
Instead of hand coding the OR and Else statements I'd just use three separate validation show if server behaviors without any code edits.
1) If first name and last name fail around the message "neither the first name nor last name can be blank"
2) If first name fails and last name passes use "first name cannot be blank"
3) If last name fails and first name passes use "last name cannot be blank"
Jamie
gotcha, thanks
