XSS issue: scan result says the scripts are vulnerable but cannot tell where
Thread begun 11/10/2017 2:53 am by rikaG_510 | Last modified 11/27/2017 11:45 am by Ray Borduin | 2219 views | 4 replies |
rikaG_510
My UK site (www.rowingcentre.co.uk) is managed by 123-REG hosting company.
Recently the site has been hacked twice. I manually managed to delete the suspicious files for the first hack but the second time I reinstalled the whole site with clean files, then bought this ‘XSS scan’ provided by the host which detect the vulnerable scripts.
Attached image is the scan result but I have no clue what parts are vulnerable.
There are two files and I used WA’s app for both of them to build so hopefully you can tell what is wrong?
At the moment there’s no error and everything is fully functional.
Thank you for your help in advance.
Rika
This is because you are displaying form values on the page directly like this:
<?php echo((isset($_POST["Full_Name"]))?$_POST["Full_Name"]:"") ?>
Users could put some code other than their Full_Name when they fill out the form and then the code would run on the page. You may actually be preventing this with server side validation, but there is no way for your testing software to know that.
You can fix these errors by using:
<?php echo((isset($_POST["Full_Name"]))?htmlspecialchars($_POST["Full_Name"]):""?>
the htmlspecialchars() function would encode anything that would allow cross site scripting.
The bad news is that this isn't how someone uploaded malicious files and hacked you. XSS allows users to get sensitive data from your customers like cookies but it isn't the type of vulnerably that opens the door to a full hack. This is worth correcting on the pages, but won't solve your larger issue.
rikaG_510
Hi Ray,
Thank you. I will fix the code as you suggested.
For the larger issues, my host provides the daily scan to detect any suspicious action through FTP, so not worried so much for the time being.
But certainly I will learn more about XSS :)
Rika
rikaG_510
Hi Ray,
I fixed the parts you spotted in the way you suggested. One file is marked as safe, but the other one (attached) is still vulnerable.
I did make changes where I could, but I don't know what else is needed to be done. Could you kindly advise me, please?
Thank you for you help.
Rika
The same issue on lines 420, 424 and lines 491-503
All of them meed htmlspecialcharacters() added like you have on the other lines.
