Validation and other items
Thread begun 10/27/2017 8:57 am by Steve | Last modified 10/27/2017 3:15 pm by Ray Borduin | 3609 views | 7 replies |
Steve
where do we fix the validation when you enter 10 digits for phone but the wizard generated form complains?
The logic on eCart seems a bit confusing..
1) the Wizard pages can not be regenerated right? Meaning you need do a full regeneration if you're concerned there is an error.
2) is there a basic expected flow? Add to cart -> checkout -> take personal and billing info OR add to cart -> some confirm page (confirm.php) where you edit or delete then move to final Checkout page?
Frustrating also when you update a Add to Cart button but the attributes don't update the function...
Battling away but growing weary.
That looks like a client validation message. So it is probably on the field itself. If you post a URL I could take a look.
1) The wizard shouldn't be re-run after customization. The individual components on the page can be edited through server behaviors or dreamweaver directly.
2) You can do it however you want, but usually people do Add to cart - > View and update cart - > Checkout
I'm not sure what you are editing or where. It might make sense to give me FTP information. Concentrate on one problem at a time and post specific details here and I'll help you through it.
Steve
Ok, so checkout.php actually uses pages confirm_cart.php and confirm.php which could be easily thought of as being the order review pages.
I will create order_review.php and use the display manager to set a basic cart review. Then add a delete button etc
Current problem page is checkout (phone number client side validation) and not understanding why there is a continue button when the Payment Info button will actually move to complete the Order.
Steve
FTP info added to PM
The issue with the phone number is in the pattern attribute on the <input> field. The formatting is done in the onblur event. You could remove or adjust both to allow more digits and stop formatting the entered value.
The continue button is there because when the wizard runs, usually the payment info div isn't visible. The continue button would refresh the cart in case the shipping had changed and expose the payment div.
Something you have done has made the payment div show by default and made the continue button not make sense.
I think the problem stems from you not having uploaded some of the necessary scripts.. Try uploading the webassist and WA_eCart directories. They both have .js and .css files that the page uses that aren't on your server. I can see there are actually 13 files referenced on your page that don't currently exist on your server.
Steve
Yes, missing files was an issue. Also that the webassist directory was a virtual directory that confused paths and has now been remedied (IIS).
It looks like your page is missing a reference to the Ledge.css file that adds the validation styling. That is why the errors appear on the bottom of the page.
Steve
Yes, I removed it as I am trying to only use a custom styles and bootstrap4
I returned /jq_validation/Ledge.css and the Checkout page is working nicely. Thanks!
Now I'll move to creating a clean static add to cart button and then be able to place my own variables. The current ones added keep referencing a Recordset such as "outstanding".
// WA eCart MySQLi AddToCart
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"])) {
$ATC_itemID = $_POST["eCart1_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "checkout.php";
$ATC_RedirectIfIn = "";
if (function_exists("rel2abs")) {
$ATC_RedirectIfIn = $ATC_RedirectIfIn?rel2abs($ATC_RedirectIfIn,dirname(__FILE__)):"";
$ATC_RedirectAfter = $ATC_RedirectAfter?rel2abs($ATC_RedirectAfter,dirname(__FILE__)):"";
if ("outstanding" != "") $outstanding->FindRow("round(sum(invValue),2)",$ATC_itemID);
$ATC_itemName = "".((isset($_POST["invoiceID"]))?$_POST["invoiceID"]:"") ."";// column binding
$ATC_itemDescription = "";// column binding
$ATC_itemThumbnail = "";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = "".$_POST["eCart1_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".((isset($_POST["x_amount"]))?$_POST["x_amount"]:"") ."");// column binding
if ("outstanding" != "") $outstanding->Index = 0;
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$eCart1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
if ($ATC_RedirectAfter != "" && $eCart1->redirStr == "") $eCart1->redirStr = $ATC_RedirectAfter;
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'].($_SERVER['QUERY_STRING']?"?".htmlentities($_SERVER['QUERY_STRING']):"");
Updating the behavior still fails to clear any references to a recordset so likely best to insert one in a clean blank page...
Thanks for your help Ray!
