linking to an accordion
Thread begun 10/25/2017 7:29 am by Jamie | Last modified 10/27/2017 10:13 am by Ray Borduin | 2137 views | 4 replies |
Jamie
Hey Ray
How would I go about linking from a page to another page that has an accordion and force the accordion to open a specific panel?
eg hwo would I link to and open the accordion panel with the title 'maps' on this page https://goo.gl/Joq1NZ?
Cheers
Jamie
You would have to look up how to do that with the accordion you use. (Jquery?)
There should be a way to set the default panel, and then from there you could make it dynamically set through a url parameter you pass into the page.
Jamie
its this one http://api.jqueryui.com/accordion/ and have been trying to figure out what to do but no idea....
It looks like the accordion has an "active" property to set the active window... so:
Initialize a accordion with the active option specified.
$( ".selector" ).accordion({ active: 2 });
would set the second value to the active one. You could pass that value in through the url and write it dynamically with <?php echo(); ?> like:
$( ".selector" ).accordion({ active: <?php echo(isset($_GET['active']?$_GET['active']:"1")); ?> });
Jamie
Thanks. Will try and give it a go
