DataAssist Pages gives error
Thread begun 10/24/2017 2:24 am by Scythar | Last modified 11/01/2017 12:10 pm by Ray Borduin | 2413 views | 5 replies |
Scythar
After a reinstall i get an javascript error when i try to insert a new 'DataAssist Pages'
See attachment for error
Did the secondary installer run properly? Have you tried deleting your cache .dat file in your local Dreamweaver users configuration folder?
It could be an issue with the installation. If you post a US phone number or Skype contact information I can set up a screen sharing session in order to debug this and get it working.
Scythar
Deleting the cache .dat file made DataAssist Pages work.
bdw, i use Adobe Dreamweaver CS6
Now... :)
I have an MySQL database (website of a Basketball Club),
The connection created with dynamic MySQLi Connection (primary connection, no additional Connections made) works.
Then i made a form with the DataAssist Pages using define to connect to the DynConnection, i choose the Table, key Column and a design preset.
After i few changes DataAssist makes 2 pages for me (just wanted to test them) namely _detail and _results.
After uploading, when i go to that page online i get message:
'No connection could be made because the target machine actively refused it.'
What did i do wrong?
DataAssist doesn't work with MySQLi connections in the current version. It sounds like you may have tried to use a MySQLi connection with DataAssist and that could cause the error.
Scythar
Yes, indeed i did.
What do i have to use instead, so i wpuld work with my database??
Either create and use a standard MySQL connection or create the pages with the MySQLi server behaviors instead of the data bridge wizard.
