How acheive random results from a recordset that has INNER JOIN and GROUP BY in its SELECT statement?
Thread begun 10/18/2017 4:58 pm by Nathon Jones Web Design | Last modified 6/13/2018 3:04 pm by Ray Borduin | 6055 views | 12 replies |
I have three tables:
1) Categories (catID, catNAME)
2) Link Table (linkID, catID, galleryID)
3) Gallery (galleryID, domainID, galleryIMG)
I want to display a grouped list of categories on a page only where those categories exist because an image in the gallery table is linked to that category, via the link table.
The SELECT statement I've used is:
SELECT categories.catID, categories.catTITLE, link.galleryID, gallery.domainID, gallery.galleryIMG
FROM categories
INNER JOIN link ON categories.catID = link.catID
INNER JOIN gallery ON link.galleryID = gallery.galleryID
WHERE gallery.domainID = 1 GROUP BY categories.catTITLE
This is working perfectly and I can display an image from the gallery table alongside the grouped category title.
Is it possible to make the selection of gallery.galleryIMG random though? I've tried adding RAND() but, of course, it randomises the category title, not the image.
Hope that makes sense! Thank you.
NJ
You could probably do it with a nested Select like:
FROM categories
INNER JOIN (SELECT gallery.* FROM gallery ORDER BY Rand()) AS galleryRand ON link.galleryID = galleryRand.galleryID
But that isn't very efficient. It would probably make more sense to use a second recordset to get the random image after retrieving the category result.
Error in SQL syntax?
Sorry since I bring the table in AS another name you have to update all of the references to it like:
SELECT categories.catID, categories.catTITLE, link.galleryID, galleryRand.domainID, galleryRand.galleryIMG
FROM categories
WHERE galleryRand.domainID = 1 GROUP BY categories.catTITLE
Error in SQL syntax? Have never managed to solve this.
$rsGALLERYSUBCS = new WA_MySQLi_RS("rsGALLERYSUBCS",$csdbmysqli,20);
$rsGALLERYSUBCS->setQuery("SELECT NJlinkcatsubgal.NJcatSUBID, NJcategoriesSUB.NJcatSUBTITLE, galleryRand.NJgalleryID, galleryRand.NJdomainID, galleryRand.NJgalleryIMG FROM NJlinkcatsubgal INNER JOIN NJcategoriesSUB ON NJlinkcatsubgal.NJcatSUBID = NJcategoriesSUB.NJcatSUBID INNER JOIN (SELECT NJgallery.* FROM NJgallery ORDER BY Rand()) AS galleryRand ON NJgallery.NJgalleryID = NJlinkcatsubgal.NJgalleryID WHERE galleryRand.NJdomainID = $domainID AND galleryRand.NJgalleryDELETE = 2 GROUP BY NJcategoriesSUB.NJcatSUBTITLE");
$rsGALLERYSUBCS->execute();
Here's our tables and relevant fields:
NJgallery - NJgalleryID, NJgalleryIMG, NJdomainID
NJcategoriesSUB - NJcatSUBID, NJcatSUBTITLE
NJlinkcatsubgal - NJlinkcatsubgalID, NJcatSUBID, NJgalleryID (this is the link table between the gallery and the categories)
...is Rand() valid?
Hope you can clarify this one.
Appreciate any help offered.
Sorry, I've updated this to:
$rsGALLERYSUBCS->setQuery("SELECT NJlinkcatsubgal.NJcatSUBID, NJcategoriesSUB.NJcatSUBTITLE, galleryRand.NJgalleryID, galleryRand.NJdomainID, galleryRand.NJgalleryIMG, galleryRand.NJgalleryTITLE FROM NJlinkcatsubgal INNER JOIN NJcategoriesSUB ON NJlinkcatsubgal.NJcatSUBID = NJcategoriesSUB.NJcatSUBID INNER JOIN (SELECT NJgallery.* FROM NJgallery ORDER BY RAND()) AS galleryRand ON NJlinkcatsubgal.NJgalleryID = galleryRand.NJgalleryID WHERE galleryRand.NJdomainID = $domainID AND galleryRand.NJgalleryDELETE = 2 GROUP BY NJcategoriesSUB.NJcatSUBTITLE");
...which has removed the syntax error but the images aren't displaying in a random order, despite there being more than one image in each of the categories?
Thanks.
NJ
Add the ORDER BY Rand() to the end of the SQL statement instead of inside the INNER JOIN
Changed it to...
$rsGALLERYSUBCS->setQuery("SELECT NJlinkcatsubgal.NJcatSUBID, NJcategoriesSUB.NJcatSUBTITLE, NJgallery.NJgalleryID, NJgallery.NJdomainID, NJgallery.NJgalleryIMG, NJgallery.NJgalleryTITLE FROM NJlinkcatsubgal INNER JOIN NJcategoriesSUB ON NJlinkcatsubgal.NJcatSUBID = NJcategoriesSUB.NJcatSUBID INNER JOIN NJgallery ON NJlinkcatsubgal.NJgalleryID = NJgallery.NJgalleryID WHERE NJgallery.NJdomainID = $domainID AND NJgallery.NJgalleryDELETE = 2 GROUP BY NJcategoriesSUB.NJcatSUBTITLE ORDER BY RAND()");
...but it's still the same images on every load.
This is available at:
www.nathonjoneswebdesign.co.uk/waterfront/photograph-gallery.php
Try running the query in PHP MyAdmin and see if it returns more than one row. Maybe the query only has one row? I see... you are grouping by NJcatSUBTITLE, so it would only have one row. That makes your original query make more sense.
Maybe it should be:
$rsGALLERYSUBCS
$rsGALLERYSUBCS->setQuery("SELECT NJlinkcatsubgal.NJcatSUBID, NJcategoriesSUB.NJcatSUBTITLE, galleryRand.NJgalleryID, galleryRand.NJdomainID, galleryRand.NJgalleryIMG, galleryRand.NJgalleryTITLE FROM NJlinkcatsubgal INNER JOIN NJcategoriesSUB ON NJlinkcatsubgal.NJcatSUBID = NJcategoriesSUB.NJcatSUBID LEFT OUTER JOIN (SELECT NJgallery.* FROM NJgallery WHERE NJlinkcatsubgal.NJgalleryID = NJgallery.NJgalleryID ORDER BY RAND() LIMIT 1) AS galleryRand WHERE galleryRand.NJdomainID = $domainID AND galleryRand.NJgalleryDELETE = 2 GROUP BY NJcategoriesSUB.NJcatSUBTITLE");
Error in SQL Syntax
Boy this one has me whupped!
I'm grouping by NJcatSUBTITLE because I only want one of each sub-title to be displayed. It's the accompanying image that I want randomised as there is more than one image in each sub-category.
When I run this in PHP MyAdmin:
WHERE NJgallery.NJgalleryDELETE = 2
ORDER BY RAND()
...it returns 75 records.
It's doing everything but randomising the image.
NJ
