Hiding 1 Shipping Rule from Cart Display?
Thread begun 9/08/2009 3:43 am by Nathon Jones Web Design | Last modified 10/05/2009 3:13 pm by Jason Byrnes | 4451 views | 6 replies |
I want to apply a shipping rule, basically if particular items are in the cart a flat rate surcharge is added to the shipping charge.
I've added this as a new rule, and it displays just fine on the checkout page, however my client just wants the surcharge to be added directly to the regular shipping charge.
Is this possible? I've got the two shipping rules listed in my cart properties window, but am a little unclear on how to hide one of them.
Would appreciate any advice, thanks.
Regards
Nathon
PS. 3/4 posts down, it would appear that this forum has been compromised (link to "sexy woman").
On yur cart page, the code to display the shipping will look like:
if (!$eCart1->Rules_EOF("Shipping")) {
    while (!
        if (
$eCart1->RuleLooperValue("Shipping") > 0) {
           <tr>
              <td class="eC_IndividualCharge"><?php echo $eCart1->RuleLooperName("Shipping"); ?></td>
              <td><?php echo WA_eCart_DisplayMoney($eCart1, $eCart1->RuleLooperValue("Shipping")); ?></td>
            </tr>
$eCart1->Rules_MoveNext("Shipping");
$eCart1->Rules_MoveFirst("Shipping");
You can add an if statement to this :
<?php if($eCart1->RuleLooperName("Shipping") != "RuleName") {; ?>
so the charge will only display if the name does not equal a certain value:
    while (!
        if (
           <?php if($eCart1->RuleLooperName("Shipping") != "RuleName") {; ?><tr>
            </tr><?php } ?>
We do get some spam in the forums from time to time, we remove it as soon as possible.
Hi Jason,
I'm using ASP though. Does that mean I have no means of support now from WebAssist?
I did purchase the product at a time when you supported ASP so I'm hoping that I won't be left stranded. Thanks.
Here's the ASP code I have at the shipping section:
if (NOT WA_eCart_Rules_EOF(BABYFISHCART, "Shipping")) then
while (NOT WA_eCart_Rules_EOF(BABYFISHCART, "Shipping"))
if (WA_eCart_RuleLooperValue(BABYFISHCART, "Shipping") > 0) then
<tr>
<td class="eC_IndividualCharge">&nbsp;<%=WA_eCart_RuleLooperName(BABYFISHCART, "Shipping")%> (<%=(rsDelCountry.Fields.Item("countryname").Value)%>)</td>
<td>+ <%=WA_eCart_DisplayMoney(BABYFISHCART, WA_eCart_RuleLooperValue(BABYFISHCART, "Shipping"))%></td>
</tr>
end if
set BABYFISHCART = WA_eCart_Rules_MoveNext(BABYFISHCART, "Shipping")
wend
set BABYFISHCART = WA_eCart_Rules_MoveFirst(BABYFISHCART, "Shipping")
end if
Hope you can help, thanks.
Nathon.
OK, for ASP, the code would be:
%><% If WA_eCart_Rule LooperName(BABYFISHCART, "Shipping") <> "RuleName" Then %>
<tr>
<td class="eC_IndividualCharge">&nbsp;<%=WA_eCart_Rule LooperName(BABYFISHCART, "Shipping")%> (<%=(rsDelCountry.Fields.Item("countryname").Value )%>)</td>
</tr><% End If %>
end if
wend
end if
Will I have to hide this shipping charge, in the settings, prior to adding this code to prevent it from displaying twice?
Error
Hi. The code you've supplied is producing the following error:
Microsoft VBScript compilation error '800a03f9'
Expected 'Then'
/baby-gifts-checkout.asp, line 466
Any idea's what's causing this error?
Hope you can help. Thanks.
Nathon
A space was added where it should not be:
should be:
If WA_eCart_RuleLooperName(BABYFISHCART, "Shipping") <> "RuleName" Then
here is the full code again. I am putting it in a code block so it will not be changed:
<tr>
</tr>
end if
wend
end if
