Shipping rule doesn't work after clearing cart
Thread begun 10/17/2017 5:22 pm by phil107723 | Last modified 10/18/2017 4:22 pm by Ray Borduin | 3190 views | 7 replies |
phil107723
I have a flatrate shipping rule of adding $7 if there is an item in the cart. This works until the cart is cleared and then a new item is added so if a shopper decides they don't want the items and chooses something else, the rule only starts adding when there are 2 items added.
What have I done wrong?
You probably set up the rule to only add if there are more than one items in the cart. I'd have to see the cart file to know for sure, but that sounds like what you are describing.
phil107723
Hi Ray
Here is the code for eCart1_PHP.php.
require_once("WA_eCart_Definition_PHP.php");
class eCart1_Definition extends WA_eCartDefinition {
function eCart1_Definition($CartName, $PersistanceType, $CurrencyPrefix, $ForceDecimalsC, $DecimalPlacesC, $CurrencyAlign, $WeightSuffix, $ForceDecimalsW, $DecimalPlacesW, $WeightAlign, $NumberDisplay) {
$this->WA_eCartDefinition($CartName, $PersistanceType, $CurrencyPrefix, $ForceDecimalsC, $DecimalPlacesC, $CurrencyAlign, $WeightSuffix, $ForceDecimalsW, $DecimalPlacesW, $WeightAlign, $NumberDisplay);
//start node
function ResetCalculations($itmObj) {
$itmObj->TotalWeight = $itmObj->Weight * $itmObj->Quantity;//w
$itmObj->TotalPrice = $itmObj->Price * $itmObj->Quantity;//c
$itmObj->FullDetails = $itmObj->Quantity . ' ' . $itmObj->Name . ' (' . $itmObj->ID . ')';//t
return $itmObj;
//end node
//start node
function ItemIndex($itemID, $itemName, $itemDescription, $itemWeight, $itemQuantity, $itemPrice, $itemFragrance) {
for ($n=0; $n<sizeof($this->Items); $n++) {
if ($this->Items[$n]) {
if ((strcmp($this->Items[$n]->ID, $itemID) === 0) AND (strcmp($this->Items[$n]->Fragrance, $itemFragrance) === 0)) {
return $n;
return -1;
//end node
//start node
function AddToCart($AddIfIn, $RedirectIfIn, $itemID, $itemName, $itemDescription, $itemWeight, $itemQuantity, $itemPrice, $itemFragrance) {
if (get_magic_quotes_gpc()) {
$itemName = stripslashes($itemName);
$itemDescription = stripslashes($itemDescription);
$itemFragrance = stripslashes($itemFragrance);
$inCartID = $this->ItemIndex($itemID, $itemName, $itemDescription, $itemWeight, $itemQuantity, $itemPrice, $itemFragrance);
$itemQuantity = floatval($itemQuantity);
if ($inCartID >= 0) {
if ($AddIfIn == 0) {
$this->Items[$inCartID]->Quantity = floatval($this->Items[$inCartID]->Quantity) + $itemQuantity;
if ($this->Items[$inCartID]->Quantity < 0) {
$this->Items[$inCartID]->Quantity = 0;
if ($this->Items[$inCartID]->Quantity == 0) {
$this->DeleteFromCart($inCartID, true);
else {
$this->Items[$inCartID] = $this->ResetCalculations($this->Items[$inCartID]);
if ($AddIfIn == 2 && $itemQuantity > 0) {
$this->Items[] = new eCart1_ItemDefinition($itemID, $itemName, $itemDescription, $itemWeight, $itemQuantity, $itemPrice, $itemFragrance);
if ($AddIfIn == 4 && $itemQuantity > 0) {
if ($RedirectIfIn != "") {
$this->redirStr = $RedirectIfIn;
else {
if ($itemQuantity > 0) {
$this->ResetAll();
$this->SaveCart();
//end node
//start node
function DefineRules() {
$this->Discounts = array();
$this->Charges = array();
$this->Tax = array();
$this->Shipping = array();
$this->ShippingIsTaxed = false;
//Discounts
//Charges
//Tax
//Shipping
$this->Shipping[] = new WA_eCart_Rule(urldecode("Flat%20Rate"), true, "WAEC_eCart1_FlatRate");
//end node
//start node
//eCart Rule
function WAEC_eCart1_FlatRate() {
$totalShipping = 0;
if (true && (($this->InCart("1") == true))) {
$totalShipping += 7;//Result
return WA_eCart_FormatNumber($totalShipping, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
//end node
//start node
function UpdateCart() {
$itemDelete = (isset($_POST[$this->CartName."_Delete_".$n]))?$_POST[$this->CartName."_Delete_".$n]:null;
$resetCalcs = false;
$itemID = null;
if (isset($_POST[$this->CartName."_ID_hid_".$n])) {
$itemID = floatval($_POST[$this->CartName."_ID_hid_".$n]);
if (isset($_POST[$this->CartName."_ID_list_".$n])) {
$itemID = floatval($_POST[$this->CartName."_ID_list_".$n]);
if (isset($_POST[$this->CartName."_ID_".$n])) {
$itemID = floatval($_POST[$this->CartName."_ID_".$n]);
if (isset($_POST[$this->CartName."_ID_check_".$n])) {
$itemID = floatval($_POST[$this->CartName."_ID_check_".$n]);
$itemName = null;
if (isset($_POST[$this->CartName."_Name_hid_".$n])) {
$itemName = $_POST[$this->CartName."_Name_hid_".$n];
if (isset($_POST[$this->CartName."_Name_list_".$n])) {
$itemName = $_POST[$this->CartName."_Name_list_".$n];
if (isset($_POST[$this->CartName."_Name_".$n])) {
$itemName = $_POST[$this->CartName."_Name_".$n];
if (isset($_POST[$this->CartName."_Name_check_".$n])) {
$itemName = $_POST[$this->CartName."_Name_check_".$n];
$itemDescription = null;
if (isset($_POST[$this->CartName."_Description_hid_".$n])) {
$itemDescription = $_POST[$this->CartName."_Description_hid_".$n];
if (isset($_POST[$this->CartName."_Description_list_".$n])) {
$itemDescription = $_POST[$this->CartName."_Description_list_".$n];
if (isset($_POST[$this->CartName."_Description_".$n])) {
$itemDescription = $_POST[$this->CartName."_Description_".$n];
if (isset($_POST[$this->CartName."_Description_check_".$n])) {
$itemDescription = $_POST[$this->CartName."_Description_check_".$n];
$itemWeight = null;
if (isset($_POST[$this->CartName."_Weight_hid_".$n])) {
$itemWeight = floatval($_POST[$this->CartName."_Weight_hid_".$n]);
if (isset($_POST[$this->CartName."_Weight_list_".$n])) {
$itemWeight = floatval($_POST[$this->CartName."_Weight_list_".$n]);
if (isset($_POST[$this->CartName."_Weight_".$n])) {
$itemWeight = floatval($_POST[$this->CartName."_Weight_".$n]);
if (isset($_POST[$this->CartName."_Weight_check_".$n])) {
$itemWeight = floatval($_POST[$this->CartName."_Weight_check_".$n]);
$itemQuantity = null;
if (isset($_POST[$this->CartName."_Quantity_hid_".$n])) {
$itemQuantity = floatval($_POST[$this->CartName."_Quantity_hid_".$n]);
if (isset($_POST[$this->CartName."_Quantity_list_".$n])) {
$itemQuantity = floatval($_POST[$this->CartName."_Quantity_list_".$n]);
if (isset($_POST[$this->CartName."_Quantity_".$n])) {
$itemQuantity = floatval($_POST[$this->CartName."_Quantity_".$n]);
if (isset($_POST[$this->CartName."_Quantity_check_".$n])) {
$itemQuantity = floatval($_POST[$this->CartName."_Quantity_check_".$n]);
$itemPrice = null;
if (isset($_POST[$this->CartName."_Price_hid_".$n])) {
$itemPrice = floatval($_POST[$this->CartName."_Price_hid_".$n]);
if (isset($_POST[$this->CartName."_Price_list_".$n])) {
$itemPrice = floatval($_POST[$this->CartName."_Price_list_".$n]);
if (isset($_POST[$this->CartName."_Price_".$n])) {
$itemPrice = floatval($_POST[$this->CartName."_Price_".$n]);
if (isset($_POST[$this->CartName."_Price_check_".$n])) {
$itemPrice = floatval($_POST[$this->CartName."_Price_check_".$n]);
$itemFragrance = null;
if (isset($_POST[$this->CartName."_Fragrance_hid_".$n])) {
$itemFragrance = $_POST[$this->CartName."_Fragrance_hid_".$n];
if (isset($_POST[$this->CartName."_Fragrance_list_".$n])) {
$itemFragrance = $_POST[$this->CartName."_Fragrance_list_".$n];
if (isset($_POST[$this->CartName."_Fragrance_".$n])) {
$itemFragrance = $_POST[$this->CartName."_Fragrance_".$n];
if (isset($_POST[$this->CartName."_Fragrance_check_".$n])) {
$itemFragrance = $_POST[$this->CartName."_Fragrance_check_".$n];
if (isset($itemID)) {
$this->Items[$n]->ID = $itemID;
$resetCalcs = true;
if (isset($itemName)) {
$this->Items[$n]->Name = $itemName;
$resetCalcs = true;
if (isset($itemDescription)) {
$this->Items[$n]->Description = $itemDescription;
$resetCalcs = true;
if (isset($itemWeight)) {
$this->Items[$n]->Weight = $itemWeight;
$resetCalcs = true;
if (isset($itemQuantity)) {
$this->Items[$n]->Quantity = $itemQuantity;
$resetCalcs = true;
if (isset($itemPrice)) {
$this->Items[$n]->Price = $itemPrice;
$resetCalcs = true;
if (isset($itemFragrance)) {
$this->Items[$n]->Fragrance = $itemFragrance;
$resetCalcs = true;
if (is_numeric($itemQuantity)) {
if ($itemQuantity < 0) {
$itemQuantity = 0;
if ($itemQuantity == 0) {
$this->DeleteFromCart($n, false);
else {
if ($this->Items[$n]->Quantity != $itemQuantity) {
$this->Items[$n]->Quantity = floatval($itemQuantity);
$resetCalcs = true;
if (isset($itemDelete) && $itemDelete != "") {
if ($resetCalcs) {
$this->Items[$n] = $this->ResetCalculations($this->Items[$n]);
$this->ReIndexContent();
$this->ResetAll();
$this->SaveCart();
//end node
// eCart Language Pack [En]
$eCart1 = new eCart1_Definition("eCart1", 0, "$", true, 2, 0, "oz", true, 2, 1, 0);
$eCart1->cartAction = "";
$eCart1->redirStr = "";
class eCart1_ItemDefinition {
var $ID;
var $Name;
var $Description;
var $Weight;
var $Quantity;
var $Price;
var $Fragrance;
var $TotalWeight;
var $TotalPrice;
var $FullDetails;
//define
function eCart1_ItemDefinition($itemID, $itemName, $itemDescription, $itemWeight, $itemQuantity, $itemPrice, $itemFragrance) {
//columns
$this->ID = $itemID;//n√
$this->Name = $itemName;//t
$this->Description = $itemDescription;//t
$this->Weight = $itemWeight;//w
$this->Quantity = $itemQuantity;//n
$this->Price = $itemPrice;//c
$this->Fragrance = $itemFragrance;//t√
//calculations
$this->TotalWeight = $this->Weight * $this->Quantity;//w
$this->TotalPrice = $this->Price * $this->Quantity;//c
$this->FullDetails = $this->Quantity . ' ' . $this->Name . ' (' . $this->ID . ')';//t
Can you help me edit the code as I can't use ecart until I get the activation issue sorted.
Many thanks
Phil
Please attach the actual file in the future instead of copy/paste the content so that I can open it with Dreamweaver.
It looks like your shipping rule is set up to only charge if an item with the ID = 1 is in the cart. I think you can update it to use if quantity of items in the cart is > 0 instead.
phil107723
Oops! Sorry! Just because mine isn't working and it's been a while since I was last here.
(I was wanting to add $7 when there is at least one item in the cart and not $7 per item)
How would I change that code without the use of the ecart wizard?
This is the shipping bit:
//start node
//eCart Rule
$totalShipping = 0;
//eCart Rule
//end node
And I have attached the original file this time as well.
if (true && ((sizeof($this->Items) > 0))) {
phil107723
That was fast. I'll try it out.
phil107723
Another lesson learned form the masters at Webassist .
Thank you
Phil
